Old 08-17-2012, 01:30 AM   #1
4d9r
4d9r's Avatar
GM Generator fan nut?
Put new brushes in my '59 235 generator, lost the nut that holds the fan on. Can't find a vendor.
Anybody know where I might buy one. Junkyards around here are barren.
Thanks,
Terry
4d9r is offline   Reply With Quote
Old 08-17-2012, 09:45 AM   #2
mr48chev
mr48chev's Avatar
Re: GM Generator fan nut?
Figure out what size and thread it has (maybe someone here can come up with that) and then check the Dorman cabinets at a local parts house.
You might also check the nuts on older alternators as they may have used the same size and thread.
You could get away with using an over the counter nut the right size and thread until you find the correct one but it wouldn't look right.
mr48chev is online now   Reply With Quote
Old 08-17-2012, 01:00 PM   #3
4d9r
4d9r's Avatar
Yeah, it's like an 11/16 fine thread, right between 5/8 and 3/4. No Dorman help, no older generators to be found. Really surprised nobody in the hobby is repoping them. Still lots of
gennys being run especially by the resto guys. I know they get lost because I took down another generator I had in the rafters to pirate that nut and......nope that one was gone too
Terry
Old 08-17-2012, 01:47 PM   #4
mr48chev
mr48chev's Avatar
From looking on the HAMB it's a 11/16 x 18 nut One of the posters said that Speedway has 11/16x18 jam nuts for rod ends that are thinner like the original generator nut.
http://www.speedwaymotors.com/Chrome...-LH,39163.html
The other option might be to check with the local generator/alternator/ starter rebuilders.
Old 08-17-2012, 04:14 PM   #5
Wrenchbender Ret
Alt. nut is the same size.
Wrenchbender Ret is offline   Reply With Quote
Old 08-18-2012, 10:59 AM   #6
4d9r
4d9r's Avatar
Thanks for the replies. Speedway was a help.
Knowing that an alternator nut is the same solves the problem Wrench Bender.
Terry
