Old 08-17-2012, 09:32 AM   #1
dmw319
Truck leans to one side?
Ive got a 70 stepside short bed 1/2 ton that ive owned for a few months now. Ive noticed that if you look at the truck standing about 10 feet behind the back that it leans to the left (drivers) side. The left side is lower than the right side. What might be causing this? shocks/springs are relatively new but i figure i could swap those out as a starter. anyone else ever had that issue?
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 08-17-2012, 10:02 AM   #2
cdowns
cdowns's Avatar
Re: Truck leans to one side?
it is a very common thing on old trucks due mostly to 40years of hard work the frame has taken a set it is twisted// sometimes by shimming bed and or cab can make it less noticable
Old 08-17-2012, 10:15 AM   #3
LMREESE
I had the same problem on my truck. New springs and no more problem.
67 C10 swb bored out 350 granny 4 speed
I come from a long line of moonshiners
LMREESE is offline   Reply With Quote
Old 08-17-2012, 10:20 AM   #4
CC69Rat
CC69Rat's Avatar
It is the infamous Chevy Lean. Most Chevy trucks have the problem, and my bet would be the truck has been lowered?
S10's have it, C10's .. I think it's in the way Chevy designed the trucks. I know it's goofy but search the forums for Chevy Lean and you'll find some stuff. I promise.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 08-17-2012, 10:38 AM   #5
leddzepp
Moderator
leddzepp's Avatar
Yup, Chevy lean. Most trucks 40 yrs old have it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-17-2012, 11:08 AM   #6
jtj143
jtj143's Avatar
I had an '85 K10 that was only ten years old and it leaned...the '71 leans....I just try to park on a slope :-)
'65 GMC Suburban 4X4, '71 GMC 4X4 LWB - The Yellow Eyed Monster, '86 C10 Silverado - Oldest Daughter's Pickup, '88 S15 GMC Work Truck, '95 GMC SLE 4X4 - Second Daughter's Truck, '99 K1500 GMC Suburban Road Trip Machine, 2000 C2500 W/T Utility Bed Work Truck, '03 Silverado - Wife's Grocery Getter
jtj143 is offline   Reply With Quote
Old 08-17-2012, 11:29 AM   #7
CC69Rat
CC69Rat's Avatar
just for example --
http://www.355nation.net/forum/lower...-use-them.html
If you google 'Chevy Lean Belltech' they make a spacer you can put on the top of the spring on the driver's side and correct the problem. (driver's side up 7/16" makes the rear correct itself too) I used the S10 spacer on my white truck and it worked perfectly. (96 4.3 Ext cab)
While yes, this is an S10 I'm referencing as you can see even the new Coloroados / Canyons have it. Just my opinion I think it's by design to compensate for the torsional regidity of the frame / engine mounts. I'm sure people smarter than me would know exactly why but when I drop a truck I usually have the spacers handy for this reason.
Chad
Old 08-17-2012, 11:46 AM   #8
Dunenutt
Newbee
Dunenutt's Avatar
It's not leaning, it's hiking it's leg!
Dunenutt is offline   Reply With Quote
Old 08-17-2012, 11:52 AM   #9
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
Is it parked next to a ford.
The Dude Abides.
I aint sayin, I'm just sayin.
1970 Bowtie is offline   Reply With Quote
Old 08-17-2012, 02:02 PM   #10
nate_g_2003
nate_g_2003's Avatar
My old truck (03 Ranger) had a lean as well. Lot's of them had it, known as the Ranger lean. I can't recall exactly, but I think it was due to the gas tank, battery and weight of driver all on one side of the truck.
My suburban has it too, but it leans to the right. Putting some air in my tires helps a little, but not 100%. Good to know some new/fresh springs can help out.
-Nathan-
1972 GMC K2500 Suburban "The Project"
2013 GMC Sierra 1500 SLT Z71 "The Daily Driver"
2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD
1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD
2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD
nate_g_2003 is offline   Reply With Quote
Old 08-17-2012, 02:06 PM   #11
Rdrdave
Broke and still trying
Rdrdave's Avatar
Mine leans also, but maybe because I'm from Oakland.
Rdrdave is offline   Reply With Quote
Old 08-17-2012, 02:20 PM   #12
CC69Rat
CC69Rat's Avatar
A big ole woman would fix it too.
Chad
Old 08-17-2012, 02:29 PM   #13
1972RedNeck
1972RedNeck's Avatar
That could be the cause too.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-17-2012, 03:28 PM   #14
dmw319
yall are funny! thanks for the info though. im still gunna probably throw some new shocks/springs in there when i do my front disc converstion soon though.
Old 08-17-2012, 05:11 PM   #15
MikeyMan
My cab was leaning to the right. Turns out the rubber cab mounts were shot on that side.
Had to add some washers/shims to the new mounts to make things level and match the body lines.
MikeyMan is offline   Reply With Quote
Old 08-17-2012, 05:15 PM   #16
dmw319
never thought of that either! i guess ill be able to get a closer look when i do the rear shocks/springs
