Old 08-17-2012, 06:06 PM   #1
PortalAxls
PortalAxls's Avatar
Red face Bed removal
So I went to start taking my bed off and the back does not want to come up. I removed the 8 bolts holding the bed down. This is a wooden long bed btw.
Thank you for your help!
PortalAxls is offline   Reply With Quote
Old 08-17-2012, 06:16 PM   #2
68 SHORT-STEP'N
SLOW POKE
68 SHORT-STEP'N's Avatar
Re: Bed removal
You might need about 5 more people
68 SHORT-BED-STEP-SIDE
piece by piece ,
day by day ,
I will restore this truck ,
before the 100th anniversary !!!
68 SHORT-STEP'N is offline   Reply With Quote
Old 08-17-2012, 07:11 PM   #3
PortalAxls
PortalAxls's Avatar
Re: Bed removal
Sorry! Forgot to say I was using a forklift, and some 2x4s. The 2x at the back ended up snapping after bending the bed rail a tad bit! Picking up at the rear corner on either side of the bed by hand causes the chassis to lift at the corner you lift from.
I plan on runnin 2xs from corner to corner on the next lift attempt to help spread the load.
Are there any welds I need to cut that I am just not seeing??
67 GMC K2500. 305D V6, 4 spd, rotted wood bed, and lots of rust!!
WTB: Eaton HO 4:10 or 4:11 tapered beaing gearset, or complete 3rd of either style bearing in the 4:10 ratio
Old 08-17-2012, 07:23 PM   #4
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: Bed removal
Ensure there are no exhaust hangers bolted to the cross sills under your bed...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 08-17-2012, 07:47 PM   #5
Lee H
Lee H's Avatar
Re: Bed removal
Fender braces
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-18-2012, 11:44 AM   #6
PortalAxls
PortalAxls's Avatar
Re: Bed removal
Thanks guys. The PO ended up welding some of the bumper to the bed... Bed is now off!
Old 08-18-2012, 01:47 PM   #7
davepl
davepl's Avatar
Re: Bed removal
Mine had the bumper welded to the frame and a bunch of bracketry for things like trailer lights that connected the bed to the bumper... just in case someone else comes across this thread facing a similar problem, I bet its pretty common.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
bed, bed removal
