Old 08-17-2012, 09:53 PM   #1
arturo7
arturo7's Avatar
Cab vs Panel Roof Geometry 55-59
So is the design of the panel roof a stretched out version of the cab design? Do the corners share the same geometry?
Would it be possible use the back of an aftermarket cab roof for the back of my panel?
Here is the part in question:
http://www.classicparts.com/1955-59-...tinfo/44-008A/
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 08-17-2012, 11:07 PM   #2
meter swinger
meter swinger's Avatar
Re: Cab vs Panel Roof Geometry 55-59
Its been ahwile since i got rid of the 59 burb I had so i can't remember the exact difference in the height of the roof panel above the drip rail. Burb/panels have a higher roof line above the drip rail, however, it seems like most of it was in the center. The silouette may be the same at the rear but i would try and locate a truck somewhere to get them side by side and compare.
meter swinger is offline   Reply With Quote
Old 08-18-2012, 02:03 AM   #3
arturo7
arturo7's Avatar
If it's not an exact fit, maybe I can just cut off a U shape to replace the cancer zones and gutter? Then I'll have some steel left over to address other areas. Sound reasonable?
ever forward
Old 08-21-2012, 02:02 PM   #4
buggy5872
buggy5872's Avatar
Roof is not even close to the same. What section are you looking for? Side, back? if it side then a patch can be easily made if your drip rail is ok but if you are into the drip rail....look for another pnael roof. They are bolted on most of the way around.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 08-21-2012, 08:53 PM   #5
arturo7
arturo7's Avatar
Yeah, I had a look at the truck today. Not a feasible idea.
ever forward
