Old 08-17-2012, 10:21 PM   #1
Mike Culpepper
Red
Mike Culpepper's Avatar
Damn drum!
Trying to replace the wheel cylinders and shoes on the rear of my '72 (discs up front and drums in back). Can't get adjuster to budge at ALL on passenger side, either tighter or looser. Using angled wire to pull actuating lever out prior to trying to adjust shoes OUT. Star wheel doesn't apepar to budge either in or out! ANy tips/tricks????????
Tried a MFH(medium F!@#ing hammer, but havent pulled the BFH yet!
'72 Cheyenne LWB 350/350
"The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game).
Mike Culpepper is offline   Reply With Quote
Old 08-17-2012, 10:50 PM   #2
airdale94
airdale94's Avatar
Re: Damn drum!
Break off the heads on the shoe hold down pins on the backing plate. And or try to dislodge the adjuster from the shoes. Then hammer off drums. A air hammer with a blunt punch works best. Or big punch and big hammer.
airdale94 is offline   Reply With Quote
Old 08-18-2012, 02:11 AM   #3
WIDESIDE72
WIDESIDE72's Avatar
Re: Damn drum!
I have had to grind/ drilled the heads off the shoe retaining pins then us a brake drum pulled to get drums off! (luckily only once)
WIDESIDE72 is offline   Reply With Quote
Old 08-18-2012, 11:01 AM   #4
cdowns
cdowns's Avatar
Re: Damn drum!
r u havin problem getting drum off? i dont see u stating that in your post??
Old 08-19-2012, 09:57 AM   #5
Mike Culpepper
Red
Re: Damn drum!
Sorry, yes I can't get the drum off. The star wheel doesn't want to budge so far(accessing it through the knockout in the drum).
Old 08-19-2012, 10:09 AM   #6
1972RedNeck
1972RedNeck's Avatar
Re: Damn drum!
Put a heating tip on your torch (or get a propane branding torch) and get the drum really, really hot. Throw 10 to 20 gallons of ice cold water on it. It should literally fall off.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-19-2012, 10:17 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Re: Damn drum!
You say you're trying to adjust shoes out. Is that what you meant to say?
I use a thing screwdriver to push the adjuster out of the way and then retract the shoes all the way. I have used a larger screwdriver to move the star wheel in the past but a good brake adjusting tool works a lot better. I always have to think about which way to move the star wheel on this step when I do mine. As you know the adjuster lever moves the star wheel top down on the outside so you want to go top down on the inward side to retract the shoes.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-19-2012, 10:38 AM   #8
wilbilt
wilbilt's Avatar
Re: Damn drum!
Can you get some good penetrant on the star wheel threads through the adjuster hole? Like a can of PB Blaster (using the little red tube that I always lose)?
1971 GMC C2500 Custom Camper - Second Owner.
350/TH350, Dana 60 Rear.
wilbilt is offline   Reply With Quote
Old 08-19-2012, 11:12 AM   #9
Mike Culpepper
Red
Re: Damn drum!
No I meant to say I'm trying to move shoes IN. I have been soaking the threads on the star wheel -need to go to town for more penetrating oil today.
I ordered brake locating pins in case I have to grind off these to get drum off. THe drum turns easily so I guess I'm surprised I'm having trouble. DOuble checked that parking brake is not engaged. I've got one of those star wheel screwdrivers that is angled on one end, and a bent wire to hold actuator lever off of wheel. I'll have to check to see if I have any acetylene/O2 (it's been a a long time since I used the torch). I assume the torch method won't ruin anything?
Old 08-19-2012, 11:23 AM   #10
71swb4x4
71swb4x4's Avatar
Re: Damn drum!
Isn't that the purpose of a torch? Wait to use it until you are frustrated, and then ruin the most important part in the process of trying to remove the least important part?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-19-2012, 11:33 AM   #11
68gmsee
Active Member
68gmsee's Avatar
Re: Damn drum!
I think he meant to heat the adjuster to loosen it up...
Forgot to add: or the drum around the axle.
06 Trailblazer
Old 08-19-2012, 12:31 PM   #12
cdowns
cdowns's Avatar
Re: Damn drum!
are u sure that those little spring metal things are not screwed on a few of the wheel studs and holding the drum in place?
Old 08-19-2012, 12:36 PM   #13
KEL
72 GMC
KEL's Avatar
Re: Damn drum!
just to clarify, is the drum hung up on
the shoes or frozen to the axle ?
KEL is offline   Reply With Quote
Old 08-19-2012, 05:41 PM   #14
wilbilt
wilbilt's Avatar
Re: Damn drum!
I don't think GM was using those in 1971. I have never seen them on anything older than 1982 or so. I have never replaced them after removing them (cut them off with dykes), but I know they were available from Bendix as part of their brake hardware line in the 80's-90's.
It has always been my understanding they were only there to keep the drums in place during assembly.
Old 08-19-2012, 07:48 PM   #15
Mike Culpepper
Red
Re: Damn drum!
I can't say for sure if the shoes or something else is the problem? I can't get the drum off. I also can't get the star wheel to turn at all as far as I can tell.
I can't see ANY clearance between the drum and the center of the wheel axle? I;m not sure that is the correct nomenclature or not. I am soaking the star wheel threads with PB Blaster , so we'll see.........................
Mike
Old 08-19-2012, 07:48 PM   #16
Mike Culpepper
Red
Re: Damn drum!
thanks,
Mike
Old 08-19-2012, 08:09 PM   #17
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Damn drum!
You said the drum turns easily, so the parking brake is obviously not set. My guess is the drum is worn and now has a lip that's keeping it from sliding off over the shoes. Depending on how badly it's worn, the drum may need to be replaced -- so there may be little to lose if you end up ruining it while removing it. You're doing the right thing trying to turn the star adjuster, but it's frozen and won't turn. Hopefully the PB Blaster will eventually work.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-23-2012, 07:01 AM   #18
Mike Culpepper
Red
Re: Damn drum!
Just an update, FINALLY got the drum off. Turns out didn't need to collapse shoes as the drum was seized to the hub. I took a round punch, pinged right on the drum near the hub, rotated drum and continued. Every so often I hit the outside of the drum in various places. Took about 10 minutes of this and then it broke loose. The star adjuster was NEVER going to turn! I finally got it loose by putting it in a vise and putting 1 1/2 grunts on it.
Thanks for all the advice and suggestions.
THe shoes have plenty of meat on 'em, but the drivers side has been soaked with brake fluid, so I will replace them, since my 16 yr old wants to drive her occasionally (pray for my '72!!!!)
Any favorite shoe makers? Leaning toward Monroe or Raybestos bonded shoes
Mike
Old 08-23-2012, 10:27 AM   #19
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Damn drum!
Glad you finally got it loosened up! Can't recommend a best shoe.... I got mine at NAPA, no problems.
After the star adjusters are thoroughly cleaned up and moving freely, put a thin coat of antisieze on the threads.
- Mike -
RIP El Jay
Old 08-23-2012, 10:39 AM   #20
Mike Culpepper
Red
Re: Damn drum!
On the list......was also going to put a little on the 2?-4? flat "bosses" on the backer plate where shoes contact the backer plate, and small amount where the drum rust-welded itself to the hub!
