Can anyone identify this part??
We removed it from the truck, specifically the front driver's side corner of the intake manifold, over a year and a half ago and now have no idea what it was for. Any ideas??
![]() ![]() EDIT! This was not removed from front driver's side corner of intake. It appeared that way in a photo but upon closer examination, this is incorrect. We're back to square 1 on this one. I have no idea
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431 Member of the 1-Ton Club! http://www.eastcoastcarandtruck.org Last edited by tow guys; 08-18-2012 at 11:16 AM. |
![]() Join Date: Jul 2012
Re: Can anyone identify this part??
Maybe a lifting eye?
All Day Every Day '72 C20 Cheyenne Custom Camper http://67-72chevytrucks.com/vboard/s...d.php?t=549132 |
It seems to have a bevel to the hole in the center which indicates it had a real purpose. The motor already had 2 lifting brackets besides this one so I doubt that's all it was used for but ya never know lol
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431 Member of the 1-Ton Club! http://www.eastcoastcarandtruck.org |
I have a similar one at the left rear of my intake, but it has a square hole in it to run the kick down cable through.
Interesting....our truck is a 4 speed so no kick down cable here but we're getting warmer...
1969 Custom 30 wrecker
Might be to route a power brake or PCV hose through? It appears to have a hole for an accelerator spring.
That's my guess anyway. What does the winner get? ![]()
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Windy Corner of a Dirty Street
X2 Exactly what I thought too. My '72 K5 Blazer had one of those on the driver's rear of the engine where the vacuum booster hose passed through.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
Bob, the accelerator spring part makes sense but I'm trying to determine what the large tapered hole is for. For the life of me I can't remember what it was used for and it looks kinda important and I'd like to reinstall it if I could
Anyone have a pic of this part installed so I can use it to compare notes??
#10 | |
![]() Join Date: May 2006
Did your truck have cruise control? Or, the factory cable to keep the engine from shifting to one side on acceleration, but i think that was on the passenger side...
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
I also believe it's for the vacuum line to the brake booster
#13 |
I have a bracket on ebay from an Impala. You'll notice the hole is the same. It had the power brake hose going through it. See it here:
http://www.ebay.com/itm/71-72-73-74-...item231f83065b Sometimes they have a rubber grommet in that hole too.
#14 |
![]() Join Date: Sep 2010
In the center of the first picture below, there's a bare metal part with a rubber grommet inside of the hole. This was said to be from a 72 with 10,000 miles. In the upper right corner of the second picture, from a 70 GMC, you can see a bare metal ring with a hose going through it. Could it be one of these ? . . . . |
#15 |
Steve, it looks like your second pic is spot on as it came from a 70 GMC. Apparently it is for the brake booster hose.
Thanks everyone for another session of knowledge. I suppose I should blast and paint this part for when the booster gets reinstalled huh? ![]() Tony
#16 |
Here's the entire picture . . . it was from an original, low mileage 4X4 Suburban. Maybe you can blast it and just spray clear coat on it, since it looks like it was bare metal when installed at the factory. When you put the black hose through, it will stand out as a rare part, most engines don't have !!! . . . . |
#17 |
It is for the brake booster hose. It keeps it away from the throttle linkage, so it won't interfere with it.
#18 |
just lovi it when a mystery is solved
#19 |
Thanks fellas. It'll be getting the media blast and paint treatment before reinstallation
#20 |
I'm getting ready to retrofit mine with a booster and I was wonderin' if there was something stock that supported the vac hose and here it is !
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
