WTB 1987-91 Crew cab 4x4
Just seeing if anyone knew of a 87-91 cc 4wd for sale in the southeast. I have a 88 2wd cc I was going to lower but I think I want to build a 4x4 instead. The body doesn't have to be the best because mine is pretty good. Really just need the frame and running gear but will buy the whole truck if it's not too much. Want fuel injected and would like to have overdrive but it's not necessary.
Re: WTB 1987-91 Crew cab 4x4
I have a 90 that i might sell. It is a old arkansas state truck. It has a tbi 350, th400, np205 t-case, 14 bolt rear, and dana 60 front. Body is rust free except for one small spot in the rocker panel. It has its share of dents. $3500 firm
Wouldnt it be easier to just swap in the front end. All the spring hanger mounting points on the frame are factory drilled. Find a junkyard front end and take the hangars with ya.
72 GMC Jimmy- 355-4sp-4x many more BIG dreams CONFUSEDUS say;---If you at first do not succeed, get a BIGGER hammer .....
| Bookmarks |
