08-18-2012, 11:58 AM | #1 |
Can I use stock shocks with a 3/5 drop?
I bought a set of drop springs for my truck from CPP. 3" for the front and 5" for the back. The truck has brand new stock shocks in it and was wondering if I can keep the new shocks with this drop? I've read some threads that say yes and others that say no. Some have mentioned installing a rear shock relocation kit.
Any advantages/disadvantages either way? Any info or suggestions would be appreciated. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
08-18-2012, 12:03 PM | #2 |
Moderator
Re: Can I use stock shocks with a 3/5 drop?
You need drop shocks front and rear at the minimum. If you don't believe me, try driving it and see what happens
An adjustable panhard bar and relocater brackets are also needed if you want the rear end centered and the shocks to function properly.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-18-2012, 01:51 PM | #3 |
A guy with a truck
Depends on what part numbers you have. Stock replacement shock lengths vary significantly between manufacturers, even between product lines. I know that the stock replacement blue Monroes will work, but you will definitely want relocators out back- new shocks or not. Early Classic Enterprise or Classic Performance Parts are good ones.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-18-2012, 04:00 PM | #4 |
Thanks guys......so if I get the relocators for the rear, do I need other shocks or I can use the stock ones with the relocated mounts?
08-18-2012, 07:26 PM | #5 |
A guy with a truck
Maybe. What shocks do you have?
08-19-2012, 12:37 AM | #6 |
Dont know what brand shocks r in there just yet, picking up the project next weekend.
Once I know I will update the thread. Thanks for all the info. Scott
