What to do?
Ok...I fixed the trans. leak by getting a DERALE pan and Moroso blue gasket and LOKAR anchor lock dipstick, but earlier this week I had checked the fluid level and it seemed low so I added a few more fluids into it. Now, I had put too much trans. fluid where it had a slight leak. Do I have to take out the whole pan and clean out the gasket or I just drain 2 qts or so and hope that stops the slight leak w/o removing the pan??? .
- 1967 Chevrolet C/10 SWB fleetside (New Project). ![]() - 1969 Chevrolet C/10 SWB fleetside (SOLD) ![]() - 2000 Ford Mustang 232 (DD) - 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver) |
Moderator
![]() Join Date: May 2007
Re: What to do?
Are you checking the transmission fluid with the truck warmed up and running?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: What to do?
Only when the truck is warm and not running.
Moderator
Re: What to do?
You need to check the fluid level while the truck is running to get an accurate reading.
Re: What to do?
Thanks...but what about my question. I drained 2 quarts or so, hoping that I don't have to remove the pan and clean out the Moroso blue gasket (reusable) then install again. I only ran the truck for radiator flush and around the block a couple times. Do you think this will stop the slight leak or I have to remove the whole thing and clean the rubber/steel gasket and reinstall again.
#6 | |
Re: What to do?
Re: What to do?
...I hope so. I drained close to 3qts. How much qts does our regular transmission w/ stock pan carry? My Derale pan requires 2+qts.
![]() Join Date: Aug 2008
Re: What to do?
It will eventually leak/ blow out whatever it doesn't need ( and make a huge mess) Ask me how I know!
![]() Posted via Mobile Device |
#9 | |||
"I ain't nobody, dork."
Re: What to do?
The tranny fluid will expand a bit when warm, and also it will be running through the valve body, and torque converter. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
