Old 08-18-2012, 04:49 PM   #1
That Mud Truck
Frame swap
I have a 1969 c10 2wd that i would like to convert into a 4x4.
Can i use a 71 k5 blazer frame? He'll throw in the tcase and it has everything else i need.
What would yall say a reasonable price would be for the frame or are their other options that i could use?
That Mud Truck is offline   Reply With Quote
Old 08-19-2012, 12:44 AM   #2
67c10rustbuket
67c10rustbuket's Avatar
Re: Frame swap
A blazer frame is shorter (in length) than a SWB truck frame so... no- ish. IDK if the crossmembers will bolt into your frame. Maybe?, no experience there sorry.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 08-19-2012, 01:23 AM   #3
WIDESIDE72
WIDESIDE72's Avatar
Re: Frame swap
I haveseej truck beds shortened to fit on blazer chassis. Not my cup of tea, but I have seen it.
WIDESIDE72 is offline   Reply With Quote
Old 08-19-2012, 02:08 AM   #4
That Mud Truck
Re: Frame swap
Could i extend the frame?
Is their any other options, their are some k10 projects for sale but their really pricey i would rather do the swap if i could.
Could i take the axles, steering and everything else i need off of the blazer frame and put it on the old c10 frame?
Old 08-19-2012, 12:32 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Frame swap
Pull your bed off and then start comparing the frames with your own eyeballs. Take measurements. Compare them. Then, you'll know what you have to do.
Member Nr. 2770
Old 08-19-2012, 07:54 PM   #6
GMtrucknut!!
GMtrucknut!!'s Avatar
Re: Frame swap
I have done one and it is a bit of a pain , but as already stated measure and double check. Mine was a 1969 chevy truck and used a 1969 blazer as a donor.
GMtrucknut!! is offline   Reply With Quote
Old 08-19-2012, 10:47 PM   #7
That Mud Truck
Re: Frame swap
You have any pics?
Did you extend the frame or did you leave it regular blazer length?
Old 08-19-2012, 11:02 PM   #8
gjones138
Re: Frame swap
I'll trade a LWB frame for your SWB frame if that would help you.
gjones138 is offline   Reply With Quote
Old 08-19-2012, 11:30 PM   #9
That Mud Truck
Re: Frame swap
Mine is a longbed 2wd.... I was gonna cut the bed to make it a shortbed... Im willing to buy a 4x4 long or short frame that i could use... If i got a long frame then ill cut it down but it has to be 4x4
Old 08-20-2012, 07:17 AM   #10
GMtrucknut!!
Re: Frame swap
I removed all the brackets and put everything on the shortbed frame. Unfortunately I do not have any pictures ,this was done in 1986.The worst part was measuring all the front end to keep it square so it didn't dog track .
Old 08-20-2012, 08:08 AM   #11
haysonj
haysonj's Avatar
Re: Frame swap
I started with a C10 Short bed frame (Guy told me it was a blazer frame) I put a 72 Dana 44 front under it and a 73 one ton 14 bolt under the back. Found a B&M T400/208 in a salvage yard and went from there. I set the frame on jack stands and leveled it and squared it with the wall on the side of my driveway.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-20-2012, 03:12 PM   #12
That Mud Truck
Re: Frame swap
Thats with the blazer frame?
I love the way it looks but other "trazers" look like they have much shorter beds it looks like yours is just a shortbed?
I dont know
Old 08-20-2012, 03:54 PM   #13
haysonj
haysonj's Avatar
Re: Frame swap
I dont know
No I found out it was a short bed frame when I got the body off. The guy I bought the original truck from had told me it was a K5 frame He was wrong
Old 08-20-2012, 04:23 PM   #14
That Mud Truck
Re: Frame swap
Yea i really like your truck... Hopefully i can find something quick.... Ill either get the blazer frame and put all the 4x4 stuff on my c10 frame or find a good 4x4 frame on craigslist...
Either way ill have alot of work ahead of me...
