Old 08-18-2012, 06:24 PM   #1
Lobie
AC Vacuum source
I am in the process of swapping a cummind in my suburban. With the diesel I don't have a source of vacuum to run the ac controls. Been searching around and found this pump that goes to a 2000 ford f250. Little more searching and find out its used to run the cruise control and hvac.
http://www.dormanproducts.com/p-30657-904-214.aspx
Will it be enough to run my ac controls?
87 Suburban R20 (6bt Cummins)
79 Cherokee Chief (454 from Suburban)
- both in progress
http://lobie4x4.com
Lobie is offline   Reply With Quote
Old 08-18-2012, 06:41 PM   #2
v30crewcab
v30crewcab's Avatar
Re: AC Vacuum source
I'm using the vacuum pump off the ps pump on my cummins. why don't you have one there? yours out of a bus or something? I don't see why that wouldn't work though.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 08-18-2012, 06:48 PM   #3
Lobie
When I put it in the jeep it wouldn't fit between the rails. I got rid of it. Wish I kept it.
- both in progress
http://lobie4x4.com
