Old 08-18-2012, 10:18 PM   #1
Project77
1979 Chevrolet Bonanza "Big Ten"
Okay, here is the story line! this truck hasnt been started in 5 years the guy i bought it from let his WIFE!!! drive this truck after he bought it from one of my friends and after he put a $1200 set of heads on it along with a weiland intake and a street avenger holley carb. she got it hot and then it sat for a month or so the guy drove it another 10 miles from his fathers house to his house. he thinks at the time it was a head gasket that blew so he let it set for 5 years and hasnt been started since. i just got it today for $200 because it has a rebuilt transmission and possibly a 3.73 rear end i plan on putting them in my 77 silverado. i tried to start the truck today but sounds like the starter is locked up so tmoro i am going to pull it off and clean it up a little and grease the shaft and in the mean time i am going to make sure the motor isnt locked up.
this is supposed to be a parts truck for my 77 but im not sure yet if i want to tear this whole baby apart the body is damn near rust free(besides surface rust) and the interior is in damn good condition i dont see myself being able to tear it apart just for my 77 who is a very healthy horse!
Motor:
350 (rebuilt with $1200 set of heads that were mentioned to be aluminum, wieland intake, holley street avenger carb, and only has about 5,000 miles on it all)
im not sure if the motor is still any good but if it start or even if it doesnt start i will pull it apart and send the block off to get tested and even send the heads off as well
Transmission:
Th350 with a shift kit about 3,000 miles
Rear End:
rumored to be 3.73 gears but i will pull the cover soon and check
Project77 is offline   Reply With Quote
Old 08-18-2012, 10:24 PM   #2
Project77
Re: 1979 Chevrolet Bonanza "Big Ten"
Old 08-18-2012, 10:58 PM   #3
Project77
Old 08-18-2012, 11:02 PM   #4
Project77
Old 08-18-2012, 11:05 PM   #5
Project77
Old 08-18-2012, 11:07 PM   #6
Project77
Old 08-18-2012, 11:08 PM   #7
Project77
Old 08-18-2012, 11:23 PM   #8
JRANGER
JRANGER's Avatar
nice
JRANGER is offline   Reply With Quote
Old 08-18-2012, 11:27 PM   #9
Project77
thank you JRANGER!
does anyone know anything about these types of trucks driveline wise? what sort of options these trucks had? i need some teaching on the history of this truck so i know what i got thanks
Old 08-18-2012, 11:32 PM   #10
JRANGER
JRANGER's Avatar
Wish I did...Im a simple computer geek learning how to restore mine as I go...Still trying to figure out why a guy dropped a 305 in mine to replace the 350
Old 08-18-2012, 11:34 PM   #11
frog210
^^^ Me too
frog210 is offline   Reply With Quote
Old 08-19-2012, 12:28 AM   #12
GM-power
GM-power's Avatar
Originally Posted by Project77 View Post
thank you JRANGER!
The big ten/heavy-half(F44 option) came with a bigger leaf spring stack, bigger rear brakes, and a 12 bolt. They were made to be emission exempt. The GVWR is 6200lbs which fell over the 6000lb emission mark. Basically you got a similar payload rating to a 3/4 ton, but had a 1/2 ton without the the emission crap. I hope that's what you were looking for. Nice truck by the way!
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 08-19-2012, 02:16 AM   #13
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Looks like a solid, decent retoration project. I say go for it and get that puppy up and running.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 08-19-2012, 08:26 AM   #14
88Jimmy4x4
88Jimmy4x4's Avatar
If those are $1200 aluminum heads why are they all rusty?
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 08-19-2012, 10:46 AM   #15
BIGTEN
BIGTEN's Avatar
I have that exact same truck. Dont tear it apart those are like gold of the c10s. They are beefiest trucks in the line.
BIGTEN is offline   Reply With Quote
Old 08-19-2012, 10:50 AM   #16
Firebirdjones
Neat. My 79 1 ton is a Bonanza,,,I haven't seen another Bonanza in years.
Firebirdjones is offline   Reply With Quote
Old 08-19-2012, 11:14 AM   #17
BIGTEN
BIGTEN's Avatar
Hope this helps. These are all the options mine have.
Old 08-19-2012, 03:21 PM   #18
Project77
im not sure if the heads are aluminum or not but i did notice they are the only metal on the motor that has rust(surface rust) the guy i bought it from said he believes they were aluminum but he isnt sure since it was a good 5 years ago!
Old 08-20-2012, 09:48 AM   #19
Corts60
Just here to tinker
Corts60's Avatar
Well aluminum doesn't rust so there's your answer. If there was white oxidation then you'd know.
Old 08-21-2012, 01:03 AM   #20
Ronaldo
Amen Bro, I thought the same thing...
Ron
Ronaldo is offline   Reply With Quote
