08-19-2012, 02:32 AM | #1 |
1984 k3500 window switch harness
Hey new here, not sure if this is the right place for this but anyway, i have a 1984 k3500 gmc sierra classic 4x4 and i need to find the window switch harness that plugs into the switch on the door. Any know of a place where i can get em new? none of the wrecking yards in my area will seperate en from the door. Thanks
08-19-2012, 06:43 AM | #2 |
Re: 1984 k3500 window switch harness
Here it is:
http://www.oehq.com/oeparts_PT254.htm These go bad at the pins in the connector, more often than people think. |
08-19-2012, 10:46 AM | #3 |
mines a 6 pin not 5 though. and im replacing it cuz the wires are broken off of it.
08-19-2012, 01:08 PM | #4 |
Is it PT 546? That one has 6 "cavities" for pins.
If you go to the www.oehq.com website and click on AC Delco pigtails, then select GM, 6 cavities, and female, you will get a page showing all of the GM 6 cavity pigtails/harnesses. You can match the picture to what you have and you should get what you need. I have found this website and Delco online catalog to be very handy for finding the harnesses I needed. http://www.oehq.com/pigtails.htm |
08-19-2012, 03:38 PM | #5 |
sweet found exactly what i needed. thanks a bunch.
08-19-2012, 03:54 PM | #6 |
No problem. This site is great for finding what you need and handy tips on how to keep an old square running. Post any question/problem you have and you will likely get an answer - likely more than one answer and you can pick the one you like.
