Carpet
Im sure this is already a thread, but the search function is less than stellar.
I don't want to buy per molded carpet since I will be going up the back of the cab as well Where is a good place to buy yards of auto carpet or whatever other carpet you have used? I know nothing about carpet so feel free to give me knowledge. Thank you Posted via Mobile Device |
Re: Carpet
These guys they ship http://www.perfectfit.com/15269/Carpet--Padding.html
Get extra to do the kick panels and along the door bottoms as well, I got the felt pad at a carpet place but had to search for it. Pad is hard to cut, hit the edges all around with a propane torch or a wood burner to keep it from raveling, wood burner works good for making holes as well. Leave it out on a hot day on a flat surface, not the lawn, as it will kill it. After its installed use weighted bags to hold it down till it cools. I used bags of cement for another project. Use paint on contact or spray, what ever you prefer just not too much as you want to take it off someday. For the back, I glued the pad to the metal, added the carpet, there is enough room to tuck it under the double cab lip. You can use Luan to make corners or finish as you please. Some Home depot and Lowes sell marine grade indoor out door in gray and black as well.
Retired and too busy to work. |
Re: Carpet
The back wall pad.
