WTB: Correct 72 4x4 350 Exhaust Manifolds
Looking for a set of correct exhaust manifolds for a 72 350 4x4 in good condition. The ones that I have, im not sure if they are correct. There straight down. The numbers are 3832465 RH46 and the other one is 3747038X RH25. Thanks!
1972 Chevrolet Blazer 4x4 (Almost done stay tuned) 1970 Chevrolet Pickup Longhorn CST/20 (SOLD) |
Re: WTB: Correct 72 4x4 350 Exhaust Manifolds
The correct one's should dump straight down... I'm pretty sure that all 4x4's do, just like the corvette one's.
You could get vette ramhorns... some are even 2.5" openings.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Mine are straight down. Thought that the numbers would matter. So as long as it's straight down, it's ok to use them? Thanks!
![]() Join Date: May 2007
LH and RH would be the same since they are straight dump.
My GM book shows the below number for 72 350 4WD: #336711, LH or RH non-smog (no air tube ports) #3932461, LH or RH with smog (threaded holes for air tubes)
LUCKTRUCK ![]() Last edited by LUCKTRUCK; 08-19-2012 at 11:01 PM. Reason: added comment |
only differences are the smog inlets (with or without) and the alternator mount on the drivers side (2 or 3 different types I think). 2" diameter but some corvette models had 2.5"...
But yes, 4WD all had straight down ramhorns...
Loves all GMC trucks
![]() Join Date: Jul 2010
If you didnt see this already!
http://67-72chevytrucks.com/vboard/s...=1#post5548714 Just helping. Mike |
Here's the ones that were on my Blazer. Should this be ok still to use?
perfect as long as you don't need the alternator mount on the drivers side... If you have a mount that does to your cylinder head then you are good...
I don't need the alt mount. It is mounted on the cylinder head. Thanks all for your help. So I guess I don't need them afterall. But I do need the heat riser valve for sure. Anyone got one? Thanks!
I was thinking about leaving that off of mine, seems like it really restricts the exhaust...
![]() Join Date: Mar 2003
I have several NOS heat risers. If you are interested post your email and I will send some pictures.
Pm sent to Ridgeback. msgross, thanks for the advice.
#13 |
no prob...
#14 |
Luis_gz06
Price is $50 shipping included |
#15 |
Interested! Can you send pics to: Luis_gz06@yahoo.com
#16 |
Luis_gz06
I will dig one out this afternoon and get you some pictures. |
#17 |
Luis_gz06
Sent you an email with the pics. |
#18 |
Got the pics, thanks! Are you firm on the price?
#19 |
Luis_gz06
Sent you another email. |
#20 |
Email returned!
#21 |
![]() Join Date: Jul 2007
'RIDGEbACK Icould use a couple heat riseres if you still have some available.
rockenc@vistabeam.com, Thanks Rock Dfd
72 chevy 3/4 ton 4X4 |
#22 |
rockc:
I will dig them out and send you some pics this evening or tomorrow. Thanks. |
