First off, if I posted this in the wrong section. sorry please move it accordingly.
Second.. I have been playing around with a 82 k10 making it my new camping/wood hauler. I recently swapped out the rear 12bolt for a 14bolt ff out of a 1976 k20. All went very smooth with the exception that since I have done the swap I have not been able to get my brake pressure back. I have installed new rear hard lines, new brake cylinders and now a new master since the old one looked pretty crusty. It has been bled out multiple times now and still my foots going to the floor. Anyone have any suggestions? I have looked for leaks and there is nothing.. everything is dry and I am not losing fluid. Any help much appreciated in advance! ![]()
* 1968 GMC Swb - 98% done (current restoration) * 1971 Chevy Lwb - Retired Dump Hauler * 1982 K10 Longbox - New Dump Hauler |
Square
Re: No brake pressure after axle swap
you probably need to bleed the brakes more.
Squarebody Syndicate |
bleed the brakes.. i made a positive pressure bleeder to get it done super easy when i re did everything..
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
Did you bench bleed the new master cylinder?
This may sound stupid but I noticed you didn't mention replacing the pads or shoes maybe those are shot?
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
Thanks for the replies, shoes/pads are pretty near new so I know there isn't an issue there. I did bench bleed the master, bled out at every point I could think of.. I am going to try and get a vacuum/positive pressure bleed system on next.
