Old 08-19-2012, 09:09 PM   #1
67Slider
67Slider's Avatar
TH350 Cooler Lines ?
Can anyone tell me the difference in the transmission cooler lines for a 67-70 TH350 2WD and a 71-72 TH350 2WD. When I bought the truck it had a 350SBC out of a 72 Camaro so I am thinking that's where the TH350 tranny came from too but don't know.
Matt
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 08-19-2012, 11:38 PM   #2
HotRod C/10
HotRod C/10's Avatar
Re: TH350 Cooler Lines ?
Should be identical.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 08-19-2012, 11:49 PM   #3
67Slider
67Slider's Avatar
Classic parts shows two different part #'s. Just curious what the difference is so I can buy the right set.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 08-20-2012, 02:23 PM   #4
67Slider
67Slider's Avatar
Anyone know why the two different part #'s? Does it have to do with the modulator?
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 08-20-2012, 03:36 PM   #5
72chevyk10
I built it
72chevyk10's Avatar
is one stainless steel and the other mild steel?
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 08-20-2012, 04:08 PM   #6
67Slider
67Slider's Avatar
No, the part numbers were different and it showed SS or original material. I called a local tranny shop and they said it was probably just how the lines were pre-bent. So I am going with that and will order a 67 model. Hopefully it works as they charge you more on shipping.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
