Old 08-20-2012, 12:05 AM   #1
ChevyonBillets
Chevy 5.3 Engine Help part selecting
Hello everyone, Today I purchase a chevy ls 5.3 motor .I want to add bolt on's with a daily driver in mind . I drive 110 miles a week. I want a cam that gives me a nice aggressive thumping sound but not sacrificing to much mpg??? . Beefing up the stock heads with better spring??? .
What would be a good cam and set of springs, headers ,timing chain, head gasket too choose from?????????????
ChevyonBillets is offline   Reply With Quote
Old 08-20-2012, 01:01 AM   #2
79shortbed
79shortbed's Avatar
Re: Chevy 5.3 Engine Help part selecting
LS6 springs, Comp Cams 212/218 Cam, hardened pushrods, stock everything else. You'll tell it has a bit of cam to it without sacrificing streetability. No need for different head gaskets, but you will need new head bolts, stock ones are torque to yield(one time use).
If you want to upgrade rear gears and your stall converter, call up thunder racing and get them to spec you out a cam. anywhere from their TR224, TR220, or a split duration cam, they get pretty wicked the farther up you go. Personally, money provided, I would go 3.73 or 4.10 rear gears, 3200 stall, and the TR220 or TR224/ Major springs needed, along with the pushrods, the stock ones suck. Looking at what? 375-400 hp?
1979 Custom Deluxe C10 SWB Fleetside
Help encourage me in my build.
LS 5.3 swap in progress!
79shortbed is offline   Reply With Quote
Old 08-20-2012, 05:36 AM   #3
Pop's C-10
Pop's C-10's Avatar
He doesn't have to pull tha heads to change tha valve springs..
http://www.ls1.com/forums/f7/how-rep...prings-132116/
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 08-20-2012, 09:23 AM   #4
LEEVON
Moderator
LEEVON's Avatar
x2 on the comp 212/218 cam. There is a low-lift and high-lift version. I'm not sure about the specs on the high-lift but the low is .522/.529 lift which will suit you fine, and work with the LS6 springs.
The lobe separation angle (LSA) has an effect on the "thump". LSA of 115 or 114 won't thump as much as 112 or 113, and I believe this cam is available in all of those combinations.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 08-20-2012, 11:52 AM   #5
79shortbed
79shortbed's Avatar
Oh yea. Sorry I forgot when I typed that late last night. Sorry, he is correct. No need to pull the heads, just the valve covers.
Old 08-21-2012, 07:58 PM   #6
ChevyonBillets
I started to take apart engine and found a broken valve spring. look at the push rod is not bent there is no damage, piston seem in good shape. So for sure in need upgrade on the springs.
Old 08-22-2012, 10:24 PM   #7
ChevyonBillets
My friend is selling me a Lunita hyraulic roller 221 int./221 exh. 0.558 int./0.558 exh. cam. Could this be a good street cam???
Old 08-22-2012, 11:00 PM   #8
79shortbed
79shortbed's Avatar
Going to need some LS6 springs, pushrods, and around 3000 stall. 3.73 or better gears. Got a part number for that cam?
Old 08-23-2012, 12:52 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I was gonna say, if it wasn't mentioned get a good set of pushrods. I'm running a way more radical cam, but I like Texas Speed stuff and they also offer a couple nice cams for what you'd want.
iirc when I bought mine, they had a number of packages with PRC springs, hardened rods and a cam. Just don't get comp 918's.
http://texas-speed.com/p-1157-texas-...ve-spring.aspx
They have a 220/220 "sleeper cam" and a 224/224 available in those kits with pretty good single springs and hardened rods. 113-115LSA would lump but I don't think it would torch your vacuum. You could go up to a twin spring kit and then go with a higher lift cam, but you start losing the driveability and street manners you wanted, as well as starting to stress the importance of the other supporting mods.
I'm running the tsp tsunami and street manners are....well I guess their good for what kind of truck it is, but its a handful. on the 111lsa vacuum brakes aren't really an option, so I'm on manual until I get hydrboost.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-23-2012, 01:51 AM   #10
BigDan3131
BigDan3131's Avatar
Why not just keep the stock cam and add a small turbo, when your not "on it" you will get your mileage and when you hammer it you will get your power. Is that 110 miles per day or week? If its week that's just 22 miles per day which is nothing.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-23-2012, 08:33 AM   #11
whitels1
whitels1's Avatar
I would recommend the GM Gen3 Hot cam 219/228 112lsa .525/.525, kit comes with LS6 valve springs. Matched with a nice set of long tubes and a 2800 converter it would run nice. I have been running this set up in my 99 Z28 for years I get 20mpg to work and back. She is no dyno queen but sounds good, runs good at the track and has plenty of low end. While doing the cam it's easy enough to change your oil pump and timing chain, stock stuff works just fine, no need for a double chain with a mild cam and light springs, if you have an air compressor you can pressurize your cylinders to change your valve springs, if you do end up pulling the heads, the stock gm head gaskets and head bolts work just fine. I always put a fine mist of the Permatex copper spray-a-gasket on both sides of the gasket before bolting the heads up.
Few vids of the car.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 08-23-2012, 11:29 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Cost is the only issue, with a cam being 3-700, where for even a junkyard turbo setup your at 3k with mediocre parts.
Old 08-23-2012, 05:09 PM   #13
ChevyonBillets
Thanks ,part number is Lunati 55004LUN on summit racing .com
Old 08-23-2012, 05:12 PM   #14
ChevyonBillets
My founds don't stretch for turbo set up right now, 110miles per week
