Why won't my truck start?
I swapped out the battery in Lil Red a couple of weeks ago. Last Friday I jump in for a quick trip to town. Ammeter reads 11.9V, gauges light up, radio comes on then I turn the key and nothing. Not even a click! The only thing I did was pull the cables off the old battery and put them on the replacement battery. Why won't it start?
How 'Bout them Dawgs! ![]() '10 Traverse LTZ 03 Silverado Z71 ext cab 99 Yamaha Grizzly 600 72 C10 350/350 sportside bed. 68 C30 flatbed. 350 4-speed. "I've got a good memory, it's just short!" |
Re: Why won't my truck start?
Distributor coil?
Stovebolt-It is painted |
Is the truck in neutral?
Happened to me before, I thought I needed a new starter ![]()
71 K20 64 GMC mud truck |
Check your cables. Could be corrosion or they might not be making a good contact
Posted via Mobile Device |
Active Member
![]() Join Date: Jul 2007
Yeah, check the nuetral/park switch and also recheck the battery cables - especially if they're old cables. They can corrode internally inside the battery connection and you can't see it.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
#6 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
![]() The gauges & radio take very little current so they could work even if there isn't enough current to start the truck. Are the headlight nice & bright? Try to start it with the headlights on -- do they stay on but get dimmer, or do they go dark when you turn the key? You might need to check voltages, starting at the battery, with a voltmeter (multimeter).
The Older Generation
You don't mention cleaning the cables when you swapped them. Any time you have the cables off you need to clean them good with a battery cleaning brush. Not only will dirty connections not make good contact but they will also keep your battery from charging. LockDoc
Pssst -- the ammeter reads amps, not volts.
![]() Is that why it's not called a volt meter?:lol Gonna check all these suggestions. Thanks.
Hey guys I got the same problem. Where is the neutral/park switch??
All my friends keep telling me this, but Where is it? |
And the winner is..........................................Dakota Digital transmission readout sending unit. It handles the gear readout on the dash and the neutral safety switch. I crawled under the truck and found the wire from the sending unit hanging loose. I twisted the wires together and got her started. Then I drove her on the lift and raised her all the way up. I cleaned and stripped the wires, crimped on butt splices, wrapped them in electrical tape and slipped a piece of plastic wire loom over it. Thanks for the suggestions.
