08-20-2012, 09:30 AM | #1 |
Power window harness question(s)
I have an 81 Blazer that has p/w and p/l-
Q-Is the Truck p/w and p/l harness the same? Q-Is the rear window harness part of the p/w and p/l harness? Also is there more than one motor in the rear gate for the window? It looks to be anothe rmotor in there. I have not been able to tear into it yet...Just none of it works. The rear window tried to make a noise the other day, then nothing. I took the harness out from under the dash to find the PO had cut and spliced all the wires right before the relay, I guess it is a relay..right by the pedal that it plugs into?
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
08-20-2012, 10:09 PM | #2 |
Re: Power window harness question(s)
I'm pretty sure the rear window is separate, since the only switches for it are on the tailgate and on the dash, and also have hella thicker wire.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
08-27-2012, 03:42 PM | #3 |
It is seperate, I wish I could find a manual rear gate. It would be damn easier than trying to figure out what is wrong with the thing!
