My 64 starting Blues
Hi everyone. I recently purchased this 64 swb fleetside with a fairly new 350. I wasn't in the market for a truck, but found a guy needing to sell, and convinced my wife by telling her we could make some money on it if we got it for a good price. They guy was wanting $4500 but I offered $1200 cash and a couple of diamond rings and he accepted. I only had $300 in the rings so I was out $1500 total. Felt pretty good at this point. I knew it needed a few things: driver's door latch, ignition lock, steering box, and a few other odds and ends.
And then the fun began. The next day she wouldn't start. I replaced the ignition switch along with the lock cylinder, but it didn't help. My initial thought was the battery, as the truck had been sitting a while I figured the battery may have been weak. But, put a different battery in still nothing. The odd thing is, I'll leave it alone for a day, go out & turn the key to run, the lights, horn, etc. will work for a few seconds, but won't start therafter the accessories won't work. Does the same thing with the other battery. I'm afraid it's the wiring, but don't know where to start. If anybody has experienced something similar, I'd appreciate any suggestions. Here are some pics (hopefully I posted right). |
![]() Join Date: Aug 2010
Re: My 64 starting Blues
It could be as simple as cables/connections. Is everything in good shape, clean and tight?
there is the main wire plug in at the fire wall to the right of the master cyl. pull that apart (disconnect) clean up the terminals w/dialectic grease and put back together. just wiggling it sometimes gets it to make contact, but is best to clean and grease. you may also have grounding problems elsewhere , battery cables going green
ron |
Engine bay wiring looks okay. Under the dash is a little messy. I don't know if it's worth it to attempt to go through all the wiring and locate it, or get a new harness. My experience with electrical is pretty limited, so I admit, I'm a little intimidated.
did you check that connection or just look at it. old wiring may look ok; there are lots of things in this life that look good or ok, but one gets surprised by looks
ron |
I plan on checking as soon as I get home, thanks for the suggestion. When you say "to the right of the MC", is that when standing in front of the truck looking into the engine bay?
#7 | |
ron |
maybe the old girl is feeling a little put out for being sold for such a small amount of $$$, and she is messing with you
![]() Sorry, couldn't help myself. Nice truck. I have found that wiring gets less intimidating when you chase one wire at a time. Eventually you should find the offending wire/connector. Question, is it not even turning over? Are you certain there is lots of charge in the battery(s). I would recommend getting a little tester light, mine is a bit like a screw driver with a light in it, and a wire lead to connect to ground. Good luck, and post back up as you go. Someone on here will suggest the thing that fixes your trouble. Cheers!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I would say the ignition switch.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#10 | |
That's what I thought as well, but I replaced ignition switch and still nothing. My next course of action is cut off the pigtail connector and hard wire the switch and see if that works. The wires going into the plug look a little boogered; perhaps there is a bad connection there.
Never Ending Projects
Do you own a test light? If not, stop where you are at and get one. Start checking circuits to see if you are even getting power to them with the key on.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#13 |
![]() Join Date: Sep 2006
It might be a bad battery cable. I would change those and see.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#14 | |
Seriously check and see if you have any power at the fuse box. If you have power there start chasing wires until you find where you don't have power. If you don't have any power at the fuse box, then chase the problem back towards the battery. Don't get frustrated, this is fun... really!
#15 |
I had a similar ignition gremlin that I fought for years. It was totally intermittent, sometimes worked fine, sometimes not at all. I finally tracked it down to a bad connection on the starter solenoid. I feel for you, it's no fun.
1961 Apache 10 SWB ![]() |
#16 |
![]() Join Date: Sep 2011
I'm sorry to hear about your troubles but it is a very nice-looking truck great price too.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
#17 |
Well, the good new is I managed to get it to crank. I decided to start simple and I just replaced the battery cable terminals as the other ones looked to be making contact, but seemed loose. Also checked that I had a good connection at harness plug next to MC as was suggested. So, that restored my power.
Bad news is I couldn't get it to turn over. I tried for a couple of minutes but my already weakened battery crapped out on me. Now, I need to recharge it or get a new one. I'm anticipating more problems getting it started. I'm guessing the carb isn't tuned properly among other things. When I was looking at the truck prior to buying, the PO would already have it warmed up, so I never got to witness a cold start. I appreciate all the input. Comparatively speaking, I'm certainly an amateur mechanic, but enjoy the learning curve nonetheless. |
#18 |
One step at a time my good man, get the battery charged, then see how it starts. You know it runs, as you witnessed it running, just need to get it started and solve the little issues as you go. If the battery is fully charged, and yous till have issues with it turning over, then you will need to disconnect clean, and re-install the batter cables, at both ends. Also, have a look at the power connections on the starter. Once you get it running, I would check the timing, and check for vacuum leaks before I started adjusting the carb. For $3 or $4 a PCV valve could quickly be ruled out as part of the problem. Pull out a spark plug, see how they look. When you get it running, run it at night and check to see that you don't have any plug wires arcing anywhere.
This is the fun of owning and working on one of these old trucks. From what pictures you have posted, $1200 to $1500 seems to be a steal. Good luck, keep us posted.
#19 |
nice find for sure
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
#20 |
I got it started today. Replaced the PCV and oil breather, and after a squirt of starting fluid she fired up.
Critical issue at this point is doing a proper PS install. PO had bolted on a PS box off of a ??, and it's barely hanging on by a couple of bolts. When I drover it home after purchasing (only 5 or 6 miles), it did great until I reached my neighborhood and it started wobbling/shaking violently for a couple of seconds and then stopped. I suspected the horrible steering setup, but haven't ruled out brakes as part of the problem. |
#21 |
Personally, I like my manual steering. Good tires make a big difference as well as a factory steering wheel. The aftermarket wheels are quite a bit smaller, and require more effort. My $0.02
Oh, and glad to hear you got it running!
#22 |
I wouldn't disagree with you. I wouldn't mind switching back, but I figure since there is already a working pump, I'll go ahead and get a PS box and bracket.
#23 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=438509 also look at the last page of this build thread, this dude made it look super simple http://67-72chevytrucks.com/vboard/s...d.php?t=472559 he sings the praises of captainfabs bracket, and captain fab provides a ton of technical support on this board, you will have no worries about how it will go together, and getting support from the captain is just a click away on here
#24 |
Thanks for the links! I've looked at CaptainFab's brackets, and I'm sure I'll be ordering one. First order of business will be sourcing a gear box.
#25 |
Mine is a rebuilt from a local parts store. 80-up have Metric fittings but turn faster usually.
