Not too old to learn
Windshield seal won't suck up
Just installed a new Precision brand windshield gasket
top won't seat with body . As you see there is about 1/2 gap. When I bought this gasket the dealer said the company (Precision ) was back ordering due to new molding set up. So I waited about four months and was shipped to me. Unfortunately I was not able to install in until now, a year later. Anyone have similar problem ? Original glass, clean newly painted cab all spot weld points smooth no distortions in metal. Gasket stored in original plastic bag inside my shop.
1968 C10 a way to long restoration. |
Florida Edition
![]() ![]() Join Date: Oct 2010
Re: Windshield seal won't suck up
Same story, mine's wrinkled up in the upper corners, done by a "pro".
Gotta come out and be redone. PIA. And we are not alone, seems to be a common problem with the deluxe trim setup. Do a search on here and you'll see what I mean.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Holly cow, that's bad. I'm contacting the dealer I bought it from
and let them know . Hope it does some good. Wonder if Steele products are better ?
![]() Join Date: Mar 2010
I went thru 2 new precision gaskets, same problem.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
![]() ![]() Join Date: Jan 2011
Mine is doing it too .. the chrome trim all the way across the top of the windshield. New glass, new gasket, original trim.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
RenoKeene, suggested I do a search of the forum on the subject.
I did ,well there is a lot of us that have problems. I believe there are enough buyers on this forum alone that could find a solution from the makers , I will start with Classic Industries. Stay tuned.
![]() Join Date: Mar 2012
Strange that there are so many problems with windshield rubber from so many different manufacturers. I need a new windshield and I am afraid to order the trim. I guess I will wait a bit and see if a solution is found...
One of the First
![]() Join Date: Jan 2000
The precision gasket I installed with trim looked like RenoKeene problems. Kept massaging it until it was fairly acceptable but, after a while, it dropped in one area on the outside. I'll re-seal it and it will do it again. So, I'm replacing first chance I get. I wish the board dealers (good 'Ole truck builders) could put some pressure on the manufacture. They have to test fit these, someplace in the world. Maybe there eyes are the problem -can't see the mess of wrinkled rubber!
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
Are you using repop trim or original trim? 67-70 type of 71 -72 type. Precision fits better than steele or any of the other crap out there unfortunately. If it is a 67-70 type gasket keep working the rubber it will lay down better than what it is now .as far as corner wrinkle try working the outside of the glass (i have a dent pulling suction cup that i use to help adjust the glass in the hole which helps. Also what type of replacement glass are you using? The cheaper stuff is thinner and does not fit as well as original or the higher end glass. I have put several of these in and the repop rubber combined with repop trim sucks simple as that. Repop rubber and oem trim is ok
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
I used a windshield gasket from Brother's and it fit great but no deluxe trim.
My glass guy has been doing antique and classic cars auto glass for 30 years, After 2 precision brand gaskets he gave up !
I happen to find a G.M. nos gasket, and the third time was a charm. Perfect fit. It is a shame that you cant find a new windshield gasket for these trucks that actually fit.
Hand Crafted C-10
![]() Join Date: Aug 2006
Though this doesn't apply to 8doors original post, since he's dealing with OEM glass, it may help
someone going through a windshield change. My glass guy told me 15 years ago that many of the re-pop windshield's glass was thinner. (as 71 Super mentioned) He did mine with the OEM stainless trim & gasket but said he generally refuses the jobs because of the leak/fitage problems. My glass was repop and luckily it fit. Good luck 8doors with getting a resolution to this. Last edited by ETsC10; 08-21-2012 at 11:08 AM. |
#13 |
Hand Crafted C-10
This thread is driving me nuts because I've been here also.
I’m wondering if the re-pop folks are patterning their gaskets according to newer cars. According to RenoKeene’s photo, that seems to fit since it seems the newer car windshields are sealed because they are glued to the car and his looks like the design is been carried over to our trucks. i.e.---the inner lip of the gasket is simply cosmetic to cover the glass/car union. Maybe the inside rim of our gaskets are actually designed far differently and actually serve a purpose in the seal. Much stiffer and seem to be wedge-shaped to serve that purpose of stabilizing the glass more; hence the seal?
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... Last edited by ETsC10; 08-21-2012 at 11:07 AM. |
#14 |
I have the same problem with my new gasket also. The inner right top isn't as bad but it doesn't fit as tight as I would like it too.I went thru 3 from LMC that was way worse than this ( I wasn't thinking when I ordered the first one). I am using the original trim in a preciesion gasket ,it does fit a hole lot better.
On the 71 I have the regular gasket with no trim. will see how it fits in a few months. |
#15 |
![]() Join Date: Dec 1999
Guys I am tellin you on my personal stuff I have never had that problem with Soff Seal. JS
#16 |
Thanks Tim. thats good to knowthat theresanother good company making some good rubbers.
#17 |
If I was doing one with the trim I would only install 67-70 trim it has a long lip vs 71-72 with a short lip. Even if I was doing a 71-72 I would put the 67-70 style rubber and trim in it. Again this is what I have had the best luck doing.
#18 |
Any idea what the brand name was ?
#19 | |
Could be Precision is just making a repo of the 71-72. So your supplier offers two types ?
#20 |
Florida Edition
Yes there are two types, long leg and short leg. Mine is long leg and like I said was installed by a pro (I work at a glass house). I bet he has 8 hours in this already and it's still a turd. Went through two precision gaskets and finally the installer supplied his own (I don't know what brand). As you can see this didn't work either. I now have a OEM gasket and trim for the next try (repop glass but I have a OEM windshield if it gets that far), I have to fix this one way or another as my truck is waaaay too nice for this kind of crap (can you tell I'm pissed?). I also heard that the corner of the pinch weld might need trimed a little....
I'll let you all know what the fix is (in my case) when I figure it out.
#21 |
Florida Edition
8door...in your case if it doesn't leak you can seal it up with some black 3M sealer, should be ok. If it does leak sealing the inside would stop the leak but trap water and eventually rust.
#22 | |
a product concern. Didn't go any further. Sales guy said he handles complaints. OK......... let him know our problems. His first response was " haven't heard anything about that " After a few minutes of talking, and probing his product knowledge ,he did agree to take the complaint to management and request info from the wholesaler that sells them Precision. We also settled on a two week turn around to get back to me by phone. ![]() Like I said ...stay tuned.
#23 |
I think a lot of the problems are caused by improper installation. Most glass guys want to start at the bottom and work their way up to the top. But these winshields must be installed top first. That will eliminate a lot of the funky bunching at the top corners.
