1968 Gas Tank Reverse Relocation
What do you guys think about relocating the gas tank by basically reversing it into the bed. *Exactly how it's mounted behind the seat, but up against the front of the bed and maybe boxing it in and make it like a false front that you wouldn't really know was there?
Has anybody done it? *Pros and Cons? Posted via Mobile Device |
Re: 1968 Gas Tank Reverse Relocation
you cant carry as much cool stuff home
#3 | ||
"I ain't nobody, dork."
To go through all that work to not gain anything, and lose bed space... I don't get it personally.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#4 | |
Just thought it would look trick if done right and every one seems to have problems relocating the tank in between the frame underneath. Posted via Mobile Device |
![]() Join Date: Oct 2009
Well, it would prevent you from sitting on 20 gals. of gas in the event something went south.
The more I think about this, the more I like it. You could prob. get another bed end piece and use in back of the tank and sheet metal in over the top. The filler hose would go through the side of the bed? Hmmmn wheels are turning!
Funny, I had been thinking along similar lines for a different reason. The idea is to build a 10' bed on a 157" 1-ton frame. Problem is California limits (by code) pickup boxes to 9'. Since I only need the top rails that long, adding a solid top compartment with a 40 gal water tank at the front would make it work. Might take a look at some of the longhorn pictures to see how the extension was added forward of the bed side flanges and basically do a narrowed reverse of it and add another modified forward bed panel.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
I am a Referee of life.
I would still think that the under bed location farther to the rear would add more weight where you need it and take it away from the front.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Oh, I agree. But it seems that most of the rear tank conversions are fraught with problems that I believe are a matter of trying to shortcut or make "cooler" than the factory Blazer/Suburban installation. Attention to venting is very important. But for a straight foward, factory reliable installation, a tank could be installed up front, just protect it well.
Did that exact conversion on my 71 cheyanne long bed.lost only 8 inches in the bed . I like it much better than the under bed converssions. Basicly all I did was mount tank against the headerpanel,and mounted another used header against the tank. I some strips of closed cell foam on both sides to hold it firmly in place,I made a angle iron frame to mount the second header to,then made acover for the top. Easy,cheap,no ugly tank hanging under the truck.I will try to post some pics tomorrow Ed
