Old 08-20-2012, 05:14 PM   #1
of13swc
Wiring harness sugestions
OK. It’s about the time to re-wire. I have heard painless wiring harnesses are the best and easiest, but they seem very expensive. I did the traditional Google search and a few companies came up that were quite cheaper. So I am all ears what is the best out there for the price? If painless is the best I do not have a problem spending the money but if there is another company out there that is just as good I would love to hear about them.
of13swc is offline   Reply With Quote
Old 08-20-2012, 05:38 PM   #2
mark 66
Re: Wiring harness sugestions
I built a camaro recently and used a kit from american autowire. very nice piece. they may have one specific for your truck?
mark 66 is offline   Reply With Quote
Old 08-20-2012, 06:02 PM   #3
Beetle
Beetle's Avatar
I am bout to pull the trigger on this:
http://www.speedwaymotors.com/Speedw...ess,42872.html
I compared it to Painless and it is $200 cheaper and its the exact same thing.
Jason
TEAM C10 HOT ROD POWER TOUR
689 Short Step
68 Step
Trucks Sold: 70 GMC, 72 K5
Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins
Beetle is offline   Reply With Quote
Old 08-20-2012, 06:09 PM   #4
markreed
Interested in this as well, but with my experience, I feel like one custom made for our trucks is a must.
Been looking at this guy...
http://www.ebay.com/itm/COMPLETE-WIR...#ht_1429wt_906
Any inputs (Not trying to steal your thread!)
markreed is offline   Reply With Quote
Old 08-20-2012, 06:42 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
The best kits I've used are from Ron Francis.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-20-2012, 09:03 PM   #6
LDO
LDO's Avatar
I used a harness from Rebel Wire and was very satisfied with the quality and installation process.
LDO is offline   Reply With Quote
Old 08-20-2012, 11:04 PM   #7
MikeS.
MikeS.'s Avatar
I I bought the same American wire kit off of eBay for about $100 less, be sure to shop around on that.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 08-20-2012, 11:09 PM   #8
Narxoleptic Customs
We rewired w the $125 speedway kit. Super easy. It's what we will use on the next project.
Narxoleptic Customs is offline   Reply With Quote
Old 08-20-2012, 11:53 PM   #9
Solo2002
Solo2002's Avatar
From what I have been looking at for my truck I'm leaning to the speedway kit to but I'm having trouble hunting down all the connectors but it's the best I have seen for the money and most likely what I will use
Solo2002 is offline   Reply With Quote
Old 08-21-2012, 01:24 AM   #10
CEE1NG_RED
How about 'EZ wiring'??
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 08-21-2012, 02:17 AM   #11
ozzyman
ozzyman's Avatar
I'm assuming this kit just has to be adapted with connectors? if so where do you pick up all the proper connectors?
Active Duty Air Force 02'-Current
Proud dad of 3 girls, 1 boy and 1 TBD in Dec of 2012 - Lucky Husband
"Family owned and operated since 1969"
Dad's 66' Custom Camper - Big Family Small Budget
ozzyman is offline   Reply With Quote
Old 08-21-2012, 09:51 AM   #12
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
You can get the connectors, the copper things inside the connectors I mean for Hot Rod wires in Dallas. I had found the 60-66 AAW harness the cheapest from Carolina Classics.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-21-2012, 11:41 AM   #13
markreed
Good Call on that.
http://www.carolinaclassictrucks.com...re-500560.html
Old 08-21-2012, 12:11 PM   #14
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
Same one I used and it worked like a champ!!!!
MOTOIMPAIRED is offline   Reply With Quote
Old 08-21-2012, 12:52 PM   #15
CRGRS 66
CRGRS 66's Avatar
I will be in the market for a wiring harness as well soon myself...
DOes the sppedway kit have all of the connectors, fuse box etc.? Or is it just wires, and from there you are on your own?
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 08-21-2012, 04:44 PM   #16
ozzyman
ozzyman's Avatar
It seems that most of the cheaper harnesses are missing reverse light wiring, how difficult is it to incorporate this? I would think it would be very easy.
Old 08-21-2012, 05:40 PM   #17
LDO
LDO's Avatar
I enjoy wiring so for me it seems easy enough.
AUTO TRANS: You should have a reverse signal wire comming out of your steering column. This wire will have power when you shift into reverse. That power wire needs to be connected to your reverse lights which should already be (case) grounded. Running a seperate ground wire from the reverse light housings to your frame is recommended. Actually, I can't stress how important it is to have a solid grounding system to ensure these old trucks have good strong lights.
MAN TRANS: There should be a switch near the shifter or trans with two wires on it. Normally, there is power 'sitting' on one side of the switch and another wire running out to your reverse lights. When you place the vehicle in Reverse, the switch is made sending power out to your lights via that wire.
See, easy peasy, lemon squeezy....
Old 08-21-2012, 06:50 PM   #18
MOTOIMPAIRED
I got my harness from Speedway for like $135 and it was complete with fuse box,blinker relay, horn relay, and a all the electric connecters like headlight plugs. Each wire is labeled every few inches and there was plenty of wire length. This is the first vehicle I completly wired but I would use it again for the price for sure..
Old 08-21-2012, 07:01 PM   #19
truckdude239
truckdude239's Avatar
$135!!!!!!!!!!! :OMG: my america autoo wire kit was over 500 buxs but the best i've used
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-21-2012, 07:02 PM   #20
gmcdeadhead
gmcdeadhead's Avatar
it seems like there is a bunch of wiring kits to choose from. so which one would be the best bang for you money?
gmcdeadhead is offline   Reply With Quote
Old 08-21-2012, 07:20 PM   #21
ozzyman
ozzyman's Avatar
Speedway 20 circuit kit has more than enough to wire a truck and for $150ish, not completely plug and play but around $300+ cheaper than most kits
Old 08-21-2012, 10:31 PM   #22
of13swc
Awesome replies fellers thank you. This makes me confident I will have to pay out the butt to rewire.
Old 08-21-2012, 11:07 PM   #23
adam_wakeley
adam_wakeley's Avatar
I used the 12 circuit kit from Hot Rod Wires, but i have nothing power. I built my truck to be as simple as possible. I had no problem with the kit, I enjoy doing wiring.
adam_wakeley is offline   Reply With Quote
Old 08-22-2012, 12:06 AM   #24
MOTOIMPAIRED
ECONOMY 12 CIRCUIT MINIFUSE WIRING HARNESS Price: $139.99 EA In Stock
View LargerItem #: 91064017
Old 08-22-2012, 11:51 AM   #25
tincan1966
tincan1966's Avatar
Just an opinion- the cheaper the price the cheaper the quality. Installed an EZ wiring harness for a customer a while back. Hands down the cheapest piece of junk I ever tried to wire a truck with. Circuits are completely inadequate, no place to add anything and odd wire lengths/terminations.
There's a reason why Ron Francis, American Autowire and Painless cost more- you get more with the kit and a better, proven/tested product. Those cheap kits on Summit and Ebay are cheap for a reason.
From what I've seen, a lesser expensive kit that seems really well designed is the Rebel Wire kit.
tincan1966 is offline   Reply With Quote
