Are all 1960/1966 long fleetside beds interchangeable and correct. I've got got a 1966 long fleet and have available a 1961 long fleet I'd like to put on with little or no modifications and have it look correct for the year.
Re: Long fleet bed interchangeable-1960/1966
The frames are different on the 61 trucks so the bottom rails are not just plug and play, it will require some modifications.
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
It'll look perfectly correct for the year.
But like LT1Burb stated; the mounting to the frame will need a little modification. The frame rails are further apart on the 60-62 than they are on the 63-66. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
100% gearhead
Use the cross sills (cross braces) from the '66 bed on the '61 bed and it will then fit. Just hopefully alll the bolts don't give you too much trouble.
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. |
It looks like gmcbigbl's question has been answered. I have a related question. Will the 60-62 cab fit without modification on the 63 frame? Are all the cab mounts in the right place? Will it look correct for the year? Thanks
Posted via Mobile Device |
1961 crewcab
same issue the rear mounts are in the same spot, but the front are different, check out the faq section for some pics
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
