Old 08-20-2012, 10:34 PM   #1
sir_talk_alot
sir_talk_alot's Avatar
going to 4.10 rear gears?
so im wanting to make my truck alittle froggier. im not gonna go posi right now, but what all would i need to do in order to put 4.10s in my rear end. just change the gearing. any input would be great. or is there a cheap way of getting posi besides welding? welding wont hold on a dd. maybe a cheaper locker?
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 08-20-2012, 11:00 PM   #2
Mustard72
Mustard72's Avatar
Re: going to 4.10 rear gears?
If you are using the 12 bolt, you'll need a "4 series" carrier, I believe. GM used different differential carriers for the different ranges of gear ratios. 2 series were the highway type gears (2.73, etc.), 3 series were the mid range (3.23 or whatever), and 4 series were the stump puller, drag racer gears (4.11, 4.56, etc.). Someone else will hopefully chime in, too. I think some of the steeper 3 something gears (like 3.73 or so???) were actually used with the 4 series carrier. Basically, it depends on what you have now as to whether you can simply throw a set of 4.11 gears in there.
At the very least, your speedo won't be accurate any more.
Mustard72 is offline   Reply With Quote
Old 08-20-2012, 11:44 PM   #3
OutlawRider
Not sure on your rear end but I do believe Mustard is right. The break is 3.73 for 12 bolt and 2.76 for a 10. A 14 bolt (if 3/4 ton, not sure on a eaton) is 4.56.
A 14 bolt gear swap is pretty simple. The 10 or 12, is a little more involved.
As for welding the rear, it cheap and easy. Look up "Orb of Traction" for a good Lincoln Lock. Just be prepared to eat up some tires. As for a cheap locker, I think lock-right would be decent. But ultimately detroit would be the best.
OutlawRider is offline   Reply With Quote
Old 08-20-2012, 11:46 PM   #4
sir_talk_alot
Its a 12bolt. I'm not sure of the ratio. It may be 373, it has no probs turning the tires for a little cloud.
-Mike-
Old 08-20-2012, 11:53 PM   #5
OutlawRider
http://www.pirate4x4.com/articles/te...ta/Gear_Setup/
This really is an amazing write up.
Old 08-21-2012, 12:22 AM   #6
nbrfd007
nbrfd007's Avatar
Don't weld them!!! If you have 3:73, thats a good ratio.
nbrfd007 is offline   Reply With Quote
Old 08-21-2012, 12:38 AM   #7
jocko
jocko's Avatar
welding is not an option unless you're only going down the dragstrip with it. If you have a 3.73 12 bolt, I wouldn't change a thing - you can still be froggy when you want and only pass every other gas station. If you swap in a 4.10, you'll be stopping at them all. I (personally) don't think you'd be happy with the tradeoff - it's a high price to pay to be able to do a cooler burnout.
Old 08-23-2012, 10:33 AM   #8
msgdsrf
Carrier size is not an issue as gears are made now that are thicker and cam fit w/o shims, etc. I think you need to be sure what ratio you have now before ordering new gears though. 1970 w/350 had 3.08 as stock (no special order). 3.73's would then be about 20% incease.
msgdsrf is offline   Reply With Quote
Old 08-23-2012, 12:23 PM   #9
bonnieclyde100
as far as posi i think you can get a powertrax from summit racing and get posi without even taking out your carrier. the unit goes into your stock carrier and you dont even have to have diff set up with new shims by a pro .
bonnieclyde100 is offline   Reply With Quote
