08-20-2012, 10:43 PM | #1 |
Sloppy Steering
I have a barn fresh 1986 K-20 wih 19K original miles but the steering is remarkably sloppy. Are there any adjustments I can make or am I looking at a steering box replacement? Something else?
08-20-2012, 10:47 PM | #2 |
Re: Sloppy Steering
I always forget what it's called but the arm that goes from the box to the pitman arm is usually a major fix. AZ or Advance sells it in two pieces.
WHen I replaced the one on my Gimmer, I took a pic of the amount of threads AND measured how far out of the collar it was, and did one end at a time. The original collar was re-usable. The steering wheel was dead straight when I was done and the steering...well I felt like I was in a top heavy Ferrari at first!
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
08-20-2012, 11:15 PM | #3 |
Re: Sloppy Steering
red circle is where you adjust the steering
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker. |
08-21-2012, 05:09 AM | #4 |
Re: Sloppy Steering
Make sure the rest of the front end components are in good shape first. Adjusting the steering box won't do you any good if the ball joints/rod ends are all junk, and may harm the box more than fixing anything.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
08-21-2012, 06:48 AM | #5 |
Re: Sloppy Steering
What is the adjustment?
08-21-2012, 07:02 AM | #6 |
Re: Sloppy Steering
There are two adjustments on a steering gear: the "preload" (adjusted by the big nut which goes around the steering shaft), and the "overcenter" (as shown by the red circle above). The preload is like the "baseline tightness" of the gear, and the overcenter is what helps provide a stable feeling while you are going straight.
As has already been mentioned - make sure all your suspension components are in good shape. After that, try tightening the gear up. The service manual has the procedure on how to do this (although they recommend removing the gear from the frame). Lastly - you can crank the caster up on an K10 or K20 using tapered shims between the axle perch and leaf spring. I've gone as high as 10 degrees caster on K trucks in order to improve the stablility going down the road. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-21-2012, 09:39 AM | #7 |
Re: Sloppy Steering
There may also be play in the rag joint. A good cheap fix is to upgrade to a Jeep Cherokee intermediate shaft as it gets rid of the rag joint and replaces it with a Borgenson joint.
08-21-2012, 10:53 AM | #8 |
Re: Sloppy Steering
Anymore info on this swap? Took a quick look around here but couldn't find anything.
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
08-21-2012, 11:38 AM | #9 |
Re: Sloppy Steering
08-21-2012, 01:00 PM | #10 |
Moderator
Re: Sloppy Steering
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 08-21-2012 at 01:12 PM. |
08-23-2012, 10:44 PM | #11 |
Re: Sloppy Steering
I like the swap idea. What year Jeep Cherokee shaft works? Is it a Grand Cherokee shaft?
Thanks! |
08-24-2012, 08:55 AM | #12 |
Re: Sloppy Steering
standard cherokee, also known as xj. probably 88up works.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
08-24-2012, 09:12 AM | #13 |
Re: Sloppy Steering
Looks like it'd be a good upgrade, quite a bit of work though.
08-25-2012, 04:27 PM | #14 |
Re: Sloppy Steering
Check this link it isn't as involved as it looks.
http://67-72chevytrucks.com/vboard/s...rokee+steering |
08-25-2012, 04:35 PM | #15 |
Re: Sloppy Steering
Yea, I actually did it today. A little unsettling taking a grinder to the nub, overall it wasn't too bad. The steering definitely tightened up a bit.
Posted via Mobile Device |
08-25-2012, 04:54 PM | #16 |
Re: Sloppy Steering
It does seem to tighten up the steering. Only makes sense. I was looking at my Dad's 2002 Silverado and it pretty much uses the same steering shaft as the Cherokees(no rag joint with Borgenson joints)
08-25-2012, 06:24 PM | #17 |
Re: Sloppy Steering
I have notice little bumps in the steering wheel, I guess I'm just used to feeling nothing with the sloppy stock shaft.
08-25-2012, 11:32 PM | #18 | |
Re: Sloppy Steering
