Old 08-21-2012, 09:12 PM   #1
Jayschevy
High torque starter wiring question.
I just ordered a high torque starter for my 71 and I have a wiring question. My old starter has the "S" and "R" terminals. The new high torque starter I ordered has only a "S" terminal. My question is once I connect the "S" wire to my high torque starter do I just tap off the old "R" wire from My old starter?
Jayschevy is offline   Reply With Quote
Old 08-21-2012, 09:26 PM   #2
sjarrett71
sjarrett71's Avatar
Re: High torque starter wiring question.
That depends on if you have HEI or not. The "R" wire is for the points ignition.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 08-21-2012, 09:32 PM   #3
jayman68
Fun Stuff
jayman68's Avatar
The "R" wire provides full voltage to the coil during cranking, to give the points ignition system a jump. You would be ahead to go with an electronic ignition(HEI), if you don't already have one.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 08-21-2012, 09:38 PM   #4
Jayschevy
I just bought the truck and Yes I believe the it has HEI, so what do I do with the "R" wire?
Old 08-21-2012, 10:23 PM   #5
jayman68
Fun Stuff
jayman68's Avatar
Fold it over back against itself and wrap it with electrical tape.
Jay
68 C10(project)
88 Honda Accord(DD)
Old 08-21-2012, 10:51 PM   #6
Jayschevy
Old 01-18-2013, 02:29 PM   #7
9teen69
9teen69's Avatar
Howdy - similar question, I don't have HEI. Stock. I have a high torque with one terminal. How do I wire the purple and yellow wire?
DISREGARD ....exhaust too tight right now...mini starter won't fit without modifying exhaust
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
Last edited by 9teen69; 01-18-2013 at 05:21 PM. Reason: No longer using mini starter
9teen69 is offline   Reply With Quote
Old 01-18-2013, 03:53 PM   #8
cdowns
cdowns's Avatar
if there is in fact a HEI dizzy installed and the yellow wire is still in place
me i'd check into weather the resistance wire has been eliminated and a dedicated 12V wire run to fire the HEI correctly
folding over and taping up and lettin things just dangel away as loose ends invites a further problem in the future when it is the least opportune time like at midnight in the middle of nowhere in a rainstorm
