08-21-2012, 09:46 PM | #1 |
WTB front frame cossmember for rad support
i need a front frame crossmember that supports the lower radiator for a 65 c10 let me know what you have my shipping zip is 13407
08-21-2012, 10:32 PM | #2 |
Re: WTB front frame cossmember for rad support
I have one you can have for 35 plus shipping but it wont have rad hold downs on it
08-21-2012, 11:07 PM | #3 |
08-21-2012, 11:52 PM | #4 |
Yeah, I am cutting up the frame so send me a pic of what you need.
08-22-2012, 09:12 PM | #5 | |
there are three engine mount holes i need the piece to be at least 1 inch back from the most forward hole and then from there it needs to be 14 inches long total so from the fwd most hole the piece would be 13 inches long you can come down the side of frame min 1 inch that part can be longer whatever you want to do let me know if this is a good description . also do you know if the rad brackets for the frame crossmember can be ordered. would you have a picture of the crossmember i need is it strait i found one local but looks like they hooked a chain to the truck there and bent the crap out of it. thanks hope this is understandable the pice i need should have the raised section of frame on top wich i beleive is clearance for fuel pump Last edited by racingdewman; 08-22-2012 at 09:54 PM. |
08-22-2012, 09:34 PM | #6 |
But Found Her 25yrs Later!
That looks like you're missing a portion of the actual frame.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
08-22-2012, 09:53 PM | #7 |
08-22-2012, 11:09 PM | #8 |
I have that piece , I will just cut out a section, I also have the rad supports but they are for a small radiator , not a 3 row.
And that is the passenger side, correct. |
08-23-2012, 02:09 PM | #9 |
yes passenger side the peice i need should have the part that sticks up on frame i beleive this is the only part of frame that sticks up above the normal frame
08-23-2012, 10:52 PM | #10 |
UhOH, my bad, I am confused, I cut from the forward hole 15" back to the cab, did you need it the other way. I can cut it the other way but you will have to make an extra bead now.
08-24-2012, 09:15 AM | #11 |
yes it needs to be the other way it must have the peice that raises above frame on top ...do you accept paypal let me know what i will owe you thanks
