Old 08-21-2012, 10:13 PM   #1
Denee007
Denee007's Avatar
Radio ideas?
Hi! I'd like to figure out options for a radio soon. While the transmission is out, I can stand up on the floor to work on the radio panel. I have a patch panel repair, but was wondering what modern radios could work? Maybe with a decent bezel I could make a hole for whatever radio may fit. So what "other" radios have been installed vs the tiny factory face radio?
Dne'
Denee007 is offline   Reply With Quote
Old 08-21-2012, 10:25 PM   #2
G&R's57GMC
G&R's57GMC's Avatar
Re: Radio ideas?
I'm going with a hidden remote controlled radio from http://www.secretaudio.com mounted under or behind the seat.
G&R's57GMC is offline   Reply With Quote
Old 08-21-2012, 10:29 PM   #3
Denee007
Denee007's Avatar
Re: Radio ideas?
Id like this, but dont know where to get a bezel like is around this radio. I will be changing the color of my interior, maybe kind of like this beautiful interior.
Old 08-21-2012, 10:40 PM   #4
mknittle
mknittle's Avatar
Re: Radio ideas?
I have been looking{Not too hard} most modern stereos look similar to that one
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-21-2012, 10:47 PM   #5
mknittle
mknittle's Avatar
Re: Radio ideas?
I have been looking{Not too hard} most modern stereos look similar to that one. That is a nice interior but the one thing that buggs me is the modistu panel over the steerin column. they are hard to make look like they aren't an after thought.Orrie and Ogre did a nice job of integrating theirs!
Mark
My GMC build.
Old 08-21-2012, 11:34 PM   #6
arturo7
arturo7's Avatar
Re: Radio ideas?
Many of the modern radios have auxiliary input ports. Mount the AM/FM in the dash and put the CD changer where you want it. You can have an adapter cable for your MP3 or smart phone as well.
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 08-22-2012, 09:47 AM   #7
mknittle
mknittle's Avatar
Re: Radio ideas?
Do you mean the metal part?
Mark
My GMC build.
Old 08-22-2012, 10:07 AM   #8
zenchal26
zenchal26's Avatar
Re: Radio ideas?
retrosound has a radio to fit in factory opening am/fm, sd card, thumb drive, and aux input. nice unit with real metal knobs.
zenchal26 is offline   Reply With Quote
Old 08-22-2012, 10:10 AM   #9
Denee007
Denee007's Avatar
Re: Radio ideas?
Yes, the metal part, or the bezel. That really seems to tie the radio to the dash. A radio like the one in the picture are available at many stores. The one in my 67 mustang is like it. I love that radio especially with Bluetooth. The hands free phone in my Stangfix works much better than in our Mazda cx9.
If I go with that shape, style of radio, I can go ahead and work the radio opening in my Apache to fit it.
Old 08-22-2012, 11:00 AM   #10
mknittle
mknittle's Avatar
Re: Radio ideas?
You will have to make it. You should have enough practice welding sheet metal from foxing the floor. Now is as good a time as any to learn to bend the parts you need. or you could buy the patch panel and modify it.
http://www.lmctruck.com/icatalog/ca/full.aspx?Page=69
You would have it widen the hole in your dash and cut the top off the patch.
If you do it that way this is the order that I would do it.Square up the cut in the dash. Cut just enough to make it nice and flat and no more.
Then cut the patch to fit I would just use magnets to hold it in place. when you get it where you want it determine where you want the radio and mark it all the way across the part and cut it{ this is where you will replace the embossed part with a flat panel}
Now that the lower part is trimmed and cleaned up fit it and tack it.if somthing dosen't fit like you like fix it now. Now you can make the flat panel and tack it in.now look at it from a bunch of angles to make sure you like it.
DO a bunch of tack welds skipping around. don't let it get too hot, Remember you will be looking it this pate from now on.
Mark
My GMC build.
Old 08-22-2012, 01:06 PM   #11
oldcouple
oldcouple's Avatar
Re: Radio ideas?
I handmade this sorta billet one from a chunk of aluminum to fit the 10 dollar garage sale post radio. I think you could make a similar plate for most any thing. I may change it out to one with a usb, as there are no radio stations anymore, and this one is cassette, but then what would I do with all those old tapes?
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 08-22-2012, 01:35 PM   #12
Hogsophist
Re: Radio ideas?
I would get the patch panel from LMC and then install one of these:
http://www.retrosoundusa.com/products/category/id/10
the install was pretty darn easy, it fits great and the auxillary in is good. The price is not bad either.
I almost went aftermarket, but a friend talked me into the patch panel and i'm glad.
Hogsophist is offline   Reply With Quote
Old 08-22-2012, 02:56 PM   #13
Denee007
Denee007's Avatar
Re: Radio ideas?
The link below is similar to the radio in my mustang 67, mine is better! Before I attempt to install an entire patch panel, I'd like to see if I can use the metal that's there already, maybe cut and weld small pieces of sheet metal where needed to make an opening for the radio I'd really want. My question still rings about the bezel. But as Mcknittle said, I'll probably have to make a bezel like in the photo up above. I just need to buy the radio and get measurements.
I'd still like to pics of "other " radios like Oldcouples. Though I like tiny original stock looking aftermarket radio, I'd rather have what I want, like the one in custom trucks photo above!
Surely out of the hundreds of folks on here, someone has installed one; ). Will I be the first?
http://www.crutchfield.com/p_1306400...EH-6400BT.html
Old 08-22-2012, 03:23 PM   #14
mknittle
mknittle's Avatar
Re: Radio ideas?
Any way you do it you need the radio first.
Mark
My GMC build.
Old 08-22-2012, 04:03 PM   #15
_Ogre
_Ogre's Avatar
Re: Radio ideas?
your choices are very limited for a radio to fit the stock hole
the old style radios have to be wired from under the dash
i'd rather have good tunes than a good fit
patch the big hole with a flat piece curved to the dash
cut a 2''x7'' hole to fit a new style single din radio in there
single din is an iso standard that you will always be able to find a radio for your truck
most single din radios have a metal cage that you insert first
lock the cage in with tabs and a rear support
run the wires thru the hole, wire the radio and
then it's a matter of sliding in the new radio
i use the term radio very generically.
my pioneer head unit is a single din dvd player
i only use the usb port on mine
i have an 8gb mini thumb drive loaded and stuck in the usb port
hard rock and electric blues, usually played very loud
wikipedia link defines it as 2''x7''
you could always go extreme like truk
1000 watts, 2 amps, 4 component speakers, 10'' sub
shop air compressor timer
Old 08-27-2012, 08:56 AM   #16
andrew_k
Re: Radio ideas?
Yeah, go for the patch panel and Retrosound's unit. Haven't bought it yet for myself, but in terms of looks and functionality (how many cds or tapes are you going to listen to in 20 years versus loading up a usb drive) it seems the best bet
andrew_k is offline   Reply With Quote
Old 08-28-2012, 09:51 PM   #17
55dude
55dude's Avatar
Re: Radio ideas?
fix the dash and install a "radio delete" panel and just mount an amp with aux jack for mp3 player and your set as most of them hold 500+ tunes!
55dude is offline   Reply With Quote
Old 08-28-2012, 10:08 PM   #18
Jemo
Re: Radio ideas?
I smoothed the dash completely and will run all my music through my iPod.
'59 Big Window Fleetside
Jemo is offline   Reply With Quote
Old 08-28-2012, 10:24 PM   #19
hotrod1
56 - autocross
hotrod1's Avatar
Re: Radio ideas?
what will u use to power it and how will you do it. I like the idea and want to do the same.
hotrod1 is offline   Reply With Quote
Old 08-28-2012, 10:30 PM   #20
Jemo
Re: Radio ideas?
Well, it's not finished yet! But what will eventually happen is I bought an amp wiring kit from a stereo store. It goes directly from the battery to a floor bulkhead and then from the bulkhead to the amp. The iPod has a cable that runs directly to the amp so this will power the speaker, etc. I'm no expert on this but talked to a stereo shop and they told me what to buy. Once I get the truck driving, I'm going to take it back over there and have them finish it up. I ran the radio power wire from the fuse panel to the area the amp is going to sit so I hope this will likely turn it on/off so the amp isn't continually on. I'll probably hide an on/off switch under the seat and run a long iPod cable up between the seats.
Old 08-28-2012, 10:32 PM   #21
hotrod1
56 - autocross
hotrod1's Avatar
Re: Radio ideas?
is there a way to do it wireless?
Old 08-28-2012, 10:33 PM   #22
Jemo
Re: Radio ideas?
Here is a pic of how I smoothed the dash. I just used some leftover sheet metal so it was cheap to do. I also eliminated a lot of the other switches originally on the dash. I'm going to hide my a/c control in the glove box.
Old 08-28-2012, 10:35 PM   #23
Jemo
Re: Radio ideas?
I'm not sure about wireless. There might be a way but I think a cord will be unnoticeable. When it's parked, i can shove it in-between the seat so it can't be seen or hide it under the seatbelt.
On my daily driver, music can be run through an iPod but even it requires a cable so I'm not sure about wireless.
Old 10-10-2012, 10:24 AM   #24
andrew_k
Re: Radio ideas?
Does anyone have the radios that Brothers has for 55-59?
http://www.brotherstrucks.com/prodin...number=CS06300
They don't have a picture anywhere and I'm not sure how it fits into the dash repair panel, but the ad says it will drop right in. There isn't a lot of room inside that oval, so I'm not sure if it's redesigned compared to the 64-66 that's shown or if the face panel spreads out over top of the dash when it's installed.
Old 10-10-2012, 10:43 AM   #25
Sin7
Sin7's Avatar
Re: Radio ideas?
Mine is semi-shaved like Jemo's but has a unit in the dash. Hope this helps.
Sin7 = Luis
1959 Apache
Sin7 is offline   Reply With Quote
