power doors
hey guys i kno there has to be a thread somewhere on here i just cant find it technology slow lol i found a great deal on some power doors 125 each comes with new doorpanels window seals and the glass but they are power and my truck isnt power can i use them if so how do i wire them
Re: power doors
Are you asking about power windows? If so depending on the year you may need to swap doors that have power windows if you are going for factory. If it's a custom kit that may not be the case.
If you are asking about power locks a custom kit is pretty easy to make work. If you are asking about power doors I really have no idea but $125 seems way to cheap for a quality power door kit.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Re: power doors
I bought some power doors off a 87 chevy truck for 100 for both doors
wires were cut at the door jamb went to the junk yard found a suburban with power doors and just got all the wire snipped anything that was for the back doors |
Re: power doors
I have manual windows and locks I found a guy close to me that has a set of goodmark doors with power windows and power locks that is bought and lost intrest In his project was just wondering if there was a way to replace my manual stuff with the power ones
Posted via Mobile Device |
Re: power doors
What year us your truck
Re: power doors
1986
Re: power doors
I think you might be able to switch the locks and windows to your doors
but dont quote me if not you might have to put those doors your gonna buy on |
Re: power doors
As long as you have the wiring it should be plug and play. You will need the relay down by the brake pedal out of the suburban if you did not get it already. I have power windows on my son's Blazer and the harness was chopped up. We have repaired it and now just going to put it back in and see what happens...good luck
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
Re: power doors
My understanding is that the doors are the same... They all have the holes for both regulators.. Having said that, I have aftermerket doors that only have the holes for the manual regs.
Not a big deal to drill a couple of holes though. Posted via Mobile Device |
#10 | |
78K & 79C Jimmys
Re: power doors
post a pic of your fuse box,may just plug/add in my 87/88 burbs stock doors switched to manual crank no drilling the 87 was window crank/power locks,it was wired differently(colours the same,different spots in plug,watch that...
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
