Old 08-21-2012, 11:19 PM   #1
keh27
keh27's Avatar
donut gasket
what part # is the best donut gasket for 1969 350 factory manifolds to pipe?
keh27 is offline   Reply With Quote
Old 08-21-2012, 11:52 PM   #2
70cst
70cst's Avatar
Re: donut gasket
ttt
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-24-2012, 11:26 AM   #3
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: donut gasket
If you have stock ramhorn manifolds, depends on the style of pipe, whether you have a heat riser, etc.
With mine, I've never noticed the brand but have always used the steel donuts on my ramhorns to pipe...
...basically a steel ring with chamfers on both outside edges. They come in a composite too but if your
manifolds are in good shape (w/o rust pits, etc), the steel ones lasts the longest.
There's also a couple of gasket styles for use with a heat riser, etc.
Your local parts store should stock at least the donuts and they're really inexpensive...couple bucks.
Look at and measure your pipe & manifold before going shopping and check the mounting studs
while you are down there. Have fun!
ETsC10 is offline   Reply With Quote
