Old 08-21-2012, 11:24 PM   #1
Darren MagooGardner
Need some A/C help
What causes the compressor clutch to slip when I put more than 1 can of freon in? high pressure side only about 35, low side very low????. it cooled for a minute..then the clutch started slipping. I let off some of the pressure from the high side and it started pulling again...Im thinking bad compressor
Darren MagooGardner is offline   Reply With Quote
Old 08-22-2012, 12:45 AM   #2
airdale94
airdale94's Avatar
Re: Need some A/C help
Bad compressor clutch?
airdale94 is offline   Reply With Quote
Old 08-22-2012, 12:49 AM   #3
78bronzechariot
78bronzechariot's Avatar
Did the clutch make some sort of sound that is telling you it slips? or is it getting hot, or is it so bad that you can see it slipping? How does the compressor sound? I would lean toward a clutch, but if your compressor has some age on it, I would replace the whole thing, always seems with my luck I put on a clutch and compressor isn't far behind and needs replaced shortly thereafter.
78bronzechariot is offline   Reply With Quote
Old 08-22-2012, 07:56 AM   #4
mrein3
mrein3's Avatar
Before you throw parts at it, tighten the belt a bit tighter then you think you should. These things take a lot of juice to run.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-22-2012, 01:51 PM   #5
Big Block 454
Big Block 454's Avatar
I wouldn't think 35 psi on the discharge side is enough head pressure to cause a clutch or even a loose belt to slip. You should be able to turn the compressor by hand without too much effort. If not, it may be a tight compressor.
Big Block 454 is offline   Reply With Quote
Old 08-22-2012, 02:22 PM   #6
kwmech
Check your charging system. Check voltage to the pigtail that goes to the compressor
Old 08-22-2012, 09:42 PM   #7
Darren MagooGardner
Im not getting high pressure from my high side. I am leaning toward my compressor is not putting out enough. I did check my ground and hot side at comp. pigtail,it was good.
Old 08-23-2012, 07:36 AM   #8
MARKDTN
How do you know it is slipping as opposed to locking up? Are you feeding it vapor or liquid when you charge it? The later a/c units with an accumulator will accept liquid, but these will not.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-23-2012, 03:04 PM   #9
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
That is what I was thinking as well. Liquids do not generally compress. Could very well be the freon in its liquid state is hitting the internals causing the compressor lock up and when some freon is released, there is enough expansion room available for the freon to change from a liquid to gas state before it gets to the pistons of the compressor.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 08-23-2012, 10:57 PM   #10
Darren MagooGardner
This makes sense to me...but liquid or gas? how do you control this? If you put freon in on the low side it goes straight to the compressor. is it gas or liquid at that point?
I was wondering if the compressor was locking up...does this mean the compressor needs replaced? thanks..for all the feedback
Mr.Magoo
Old 08-23-2012, 11:02 PM   #11
Big Block 454
The only way it would be liquid is if you have the can upside down while charging. Either way, once it's shut off it will return to a vapor within a few minutes.
Old 08-23-2012, 11:12 PM   #12
Darren MagooGardner
My truck consists of a hurricane evaporator system with a 72 condensor and dryer.with.a 85 compressor and hoses. so if I have a 72 style accumulater (dryer) it wont accept liquid? what do I do to prevent compressor lock-up? I think that is what's going on.
Old 08-24-2012, 07:06 AM   #13
MARKDTN
If you turn the can upside down during charging you will send liquid. Leave the can right side up and put it in a pan of hot water to get it to "take".
'83 K20-TPI
'73 C10
'14 Suburban-DD
