Old 05-24-2003, 11:22 AM   #1
cheatham
I need a brake!
cheatham's Avatar
Brake Light Question
I didn't even think it worked since it doesn't come on when the parking brake is engaged. This morning I noticed that my brakes were real mushy and then the light came on. I refilled the master cylinder (it has a slow leak) and the brakes feel fine again, but the light won't go off. What controls this light, how do I make it go off?
Thanks for the info- JP
JP
MEMBER OF THE DISCS UP FRONT CLUB
1971 Chevy C10
cheatham is offline   Reply With Quote
Old 05-24-2003, 12:13 PM   #2
Hutch
Hutch's Avatar
cheatham,
You will need to equalize the pressure between the front an rear lines.
When one of the segments gets low the switch will throw that way.
The switch is between the front and rear lines and will not return by just adding fluid, you will need to bleed the side that is not leaking so that the switch will return to the middle of the cylinder.
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 05-24-2003, 12:48 PM   #3
cheatham
I need a brake!
cheatham's Avatar
Thanks, Hutch. That's about what I thought, but wanted to be sure before I have FUN!
JP
JP
1971 Chevy C10
Old 05-25-2003, 04:33 AM   #4
jimfulco
I ignored mine for a couple of days & it went out all by itself.
jimfulco is offline   Reply With Quote
Old 05-25-2003, 11:02 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Maybe WAY off base, but...
I'll toss it in the hat anyway. Several years ago I replaced my master cylinder and couldn't get the light to go out. What I *think* the mechanic did was... there's a device (proportioning valve?) on a bracket between the booster & master cyl. Brake lines to it from master cyl. & from it to brakes, and a wire (for the light). There's a button on the front of it, he pushed the button, & the light went off! Hope yours is that simple.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
