Old 08-22-2012, 01:53 PM   #1
oddjob197500
oddjob197500's Avatar
Beltech drop spindles
hello,
I have beltech drop spindles on my 68 c-10 with a 71 front disc brakes. I called beltch and they advised that they do not make a drop spindle for my year truck. How different are the 71-72 spindles from the 73 and up ????????I believe the beltech drop spindles part number starts with 31 and something else. I cant remember the rest right now. I bought the spindles a few years ago, i just installed the ccp tubular upper and lower control arms. I am having steering problems and the spindles look like they dont line completly up . I did have the same spindles on the stock upper and lower control arms in the past with no problems?????? Any help would be great.
oddjob197500 is offline   Reply With Quote
Old 08-22-2012, 02:05 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Beltech drop spindles
What year balljoints are in your CPP a-arms?
71-72 spindles are different from 73-87 spindles.
(different outer tie rod and different upper ball joint)
Belltech does make a 71-72 drop spindle.
Did you tell them you needed 71-72 spindles or 68 spindles?
Keith
Convert to disc brakes.
Old 08-22-2012, 02:09 PM   #3
lolife99
lolife99's Avatar
71-72:
3120
http://www.jegs.com/i/Bell+Tech/146/3120/10002/-1
73-87 Light Duty 1" Rotors:
3200
http://www.jegs.com/i/Bell+Tech/146/3200/10002/-1
73-87 HD 1-1/4" Rotors:
3100
http://www.jegs.com/i/Bell+Tech/146/3100/10002/-1
Keith
Old 08-22-2012, 02:11 PM   #4
oddjob197500
I have the 71-72 ball joints
Old 08-22-2012, 02:14 PM   #5
oddjob197500
The guy on the phone from beltech told me they did not make a spindle for my year truck. I guess he was new or did not know the F---- what he was taking about
Old 08-22-2012, 02:31 PM   #6
lolife99
lolife99's Avatar
Beltech makes a quality spindle.
You can buy cheaper.
http://www.performanceonline.com/ sells them every day for $229.
You can now buy disc brake standard and drop spindles for the following years:
60-62
63-70
71-72
73-87
Keith
Old 08-22-2012, 08:22 PM   #7
cleanfreak
cleanfreak's Avatar
Back to his origional question , can anybody tell the difference between the 3120 bell spindle for 71-72 , and the 3100 for 73-87 hd? The ball joints , tie rods , brakes , bearings are all the same , is there a geometry difference?
cleanfreak is offline   Reply With Quote
Old 08-22-2012, 08:27 PM   #8
lolife99
lolife99's Avatar
71-72 #3120 spindle is not the same as a 73-87 #3100 spindle.
They both take the HD rotor, caliper and bearing set.
They both take the same lower balljoint.
The upper ball joint and outer tie rod is different between these two trucks.
Keith
Old 08-22-2012, 08:30 PM   #9
Sideways
Sideways's Avatar
hello,
I have 71-72 Beltech spindles and they are a 3" drop, funny thing is they bolted right in my '80 GMC van. Sorry I don't have the part number handy but I did find it when I bought them and it was listed as 71-72 1/2 ton GM truck.
Sideways is offline   Reply With Quote
Old 08-22-2012, 08:34 PM   #10
cleanfreak
cleanfreak's Avatar
Thanks for the correction! I've been putting the 73 up tie rods and ball joints in everything new when I changeover , just didn't know 71-72 were different.
Old 08-22-2012, 08:40 PM   #11
lolife99
lolife99's Avatar
I'm not sure how that is possible or correct even if the parts bolt together.
71-72 Parts
Upper ball joint: k6124
Lower ball joint: k6117 T
Outer tie rod: es415 rl
80 GMC Van
Upper ball joint: k6136
Outer tie rod: es409 rl
All of these parts are easily looked up on line.
The lower ball joints are the same,... but thats it.
Keith
Old 08-22-2012, 10:21 PM   #12
Leroy-B1
lolife cant get the link to work is something wrong with it?
Leroy-B1 is offline   Reply With Quote
Old 08-22-2012, 10:23 PM   #13
lolife99
lolife99's Avatar
Fixed the POL link.
Keith
Old 08-23-2012, 07:59 AM   #14
Leroy-B1
I cant get the performanceonline one to work
Old 08-23-2012, 08:00 AM   #15
Leroy-B1
nevermind its working today...lol
