LMC fan shroud
I decided to go with the mechanical fan as my cooling option and got a LMC fan shroud. I just tried to fit it and the existing fan rubs on it. I didn't even think to check the fan size. It seems I have a 19 inch fan (if I am measuring correctly, tip to tip at its furthest point)
Before I go and order a 18 inch fan as I understand should have been in there, is there anything else should expect? Going to order a new fan clutch too. Just going to order up this guy with a flex-a-light clutch http://www.jegs.com/i/JEGS-Performan...52194/10002/-1 Any need for a spacer for a 350 stock application? Thanks for the replies. |
Re: LMC fan shroud
Thought about a good clutch fan for it.? I took off my steel solid fan and installed a clutch fan and Iam so happy I did. Robs less power is soo much quiter and moves more air.
Posted via Mobile Device |
Re: LMC fan shroud
Re: LMC fan shroud
Yes it has a clutch of sorts in it and when the temp goes up it will lock up and pull a lot of air through the radiator but untill then its a better way to go.
I think Summit and Jegs sell them. Posted via Mobile Device |
#5 | |
Re: LMC fan shroud
http://www.jegs.com/i/Flex-a-lite/400/5555/10002/-1 with this? http://www.jegs.com/i/JEGS-Performan...52194/10002/-1 In my head I follow what you mean, but I am unable to find said product. |
Re: LMC fan shroud
Yeah the top link is for the clutch part then you need a fan for it, not sure they sell it. but I would guess so.
I pulled mine off a 76 impala with a 400 small block Chevy made them for a long time. Posted via Mobile Device |
#8 | |
![]() Join Date: Jun 2012
Re: LMC fan shroud
Re: LMC fan shroud
Yeap that fan with the clutch unit from above.
![]() Join Date: Aug 2012
Re: LMC fan shroud
OK. Forgive my noob questions. I just did a little comparison and once I looked, it was glaringly obvious... I should do what I tell my kids to do and look with my eyes and not my mouth... hehe.
