Old 08-23-2012, 01:51 PM   #1
blackdawn
steering wheel issue
so on a recent truck i have obtained (1969 stepper) i found that if you pull up on the steering wheel it will easily come up about an inch or 2. i have the top of the steering column torn apart right now since i had to fix the turn signal switch as well. the PO really hodge podged this one together . where should i check/tighten to solve the steering wheel pulling up? thanks for any insight.
1969 c-10 short bed stepside - work in progress
blackdawn is offline   Reply With Quote
Old 08-23-2012, 02:36 PM   #2
bonnieclyde100
Re: steering wheel issue
do you mean pull it towards you ? if so i think your problem may be at the bottom where the steering shaft hooks to it. there should be a spring between the the shaft and the column to keep tension .
bonnieclyde100 is offline   Reply With Quote
Old 08-23-2012, 04:23 PM   #3
blackdawn
yes, basically pulling the shaft out of the column. i know there is a spring there, but ill check it out, maybe it wasn't set right.
Old 08-23-2012, 06:15 PM   #4
69GWC
whats it doing under the hood down by the rag joint.?
69GWC is offline   Reply With Quote
Old 08-23-2012, 06:22 PM   #5
blackdawn
rag joint is solid it appears to be taking the slack from the coupler where the upper and lower shaft meet. the little rubber sock deal just curls back it looks like
Old 08-23-2012, 09:03 PM   #6
Tinkermc
sometimes after a colapse as in a front end mishap they do that, could be spring has rusted away
Tinkermc is offline   Reply With Quote
Old 08-23-2012, 10:45 PM   #7
wilbilt
wilbilt's Avatar
Should be a rotating collar at the bottom of the column outside the firewall that is used to adjust the bearing/shaft end play.
1971 GMC C2500 Custom Camper - Second Owner.
350/TH350, Dana 60 Rear.
wilbilt is offline   Reply With Quote
