Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-23-2012, 01:51 PM   #1
tex_waco_usmc
Project Heaven in my 67!!!
Hobart Welder about to get the AXE
I got my Hobart MIG welder wired into the new shop finally after two years of sitting in storage. Went to weld with it and the welds laid out like a row of dimes, but they looked funny... After some investigation the bottle is turned on but there is no gas coming out of the welder to the welds...
Does anyone have any clue what I need to look at to get this thing working properly so I can start tack welding these filler plates in????
tex_waco_usmc is offline   Reply With Quote
Old 08-23-2012, 02:08 PM   #2
mongoose
mongoose's Avatar
Re: Hobart Welder about to get the AXE
reg. on? bottle full? lol
see if there's power going to the gas solenoid.. through the trigger.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 08-23-2012, 02:13 PM   #3
tex_waco_usmc
regulator is on, bottle is about half full...
Will check the power going to the gas solenoid tonight and let you know! Best way to test?
Old 08-23-2012, 02:18 PM   #4
jeff967
can you hear gas flow inside the machine while the trigger is pulled? if so the gas line in the machine has come lose.
or the gas flow solenoid is bad.
good luck
jeff967 is offline   Reply With Quote
Old 08-23-2012, 02:18 PM   #5
mongoose
mongoose's Avatar
plug it in.. and use a test light on the feed line from the trigger.
if it has power.. see if the solenoid clicks..
Old 08-25-2012, 12:02 PM   #6
jeff967
find it?
Old 09-04-2012, 03:13 PM   #7
tex_waco_usmc
Originally Posted by jeff967 View Post
find it?
Sorry it took me so long to get back, things have been extremely hectic lately! I havent had a chance to test as of yet, however, planning on getting out there tonight to verify! A buddy of mine said that if I was running "flux core" wire it would cause my welds to look funny as well! I am not sure what kind of wire is in it except that it is .024 wire (someone wrote that in marker on the spool)... How would I know if this is flux core wire?
I do know that I am not getting gas out of the handle when I hit the trigger but could it possibly be a combination of problems?
Old 09-04-2012, 03:24 PM   #8
jeff967
never saw .024 fluxcore, all gas flow possibles are listed above. I'd bet it is the gas line inside the machine lose on one end or the other
Old 09-04-2012, 05:18 PM   #9
ssapach
ssapach's Avatar
If you have flux core wire then you will have a slag on your weld similar to a stick weld.
Plain old bare mig wire won't leave a slag behind.
ssapach is offline   Reply With Quote
Old 09-05-2012, 04:20 PM   #10
tex_waco_usmc
Ok so I went out and pulled the welder out and now for some reason it seems to be working! I got some pics of everything I will post up when I get back to my computer!
Old 09-05-2012, 07:40 PM   #11
tex_waco_usmc
This is the welder that I am working with! It is an older Hobart that I bought years ago.
Name:  Welder photos.jpg
This is the regulator setup that I have on my bottle!
Name:  Welder photos3.jpg
Today I went out and hit the trigger and heard gas come out of the handle. So I laid down this weld. I know the weld looks crappy but I didnt change the settings on my welder for the thickness of this metal or wire speed or anything it was just a test weld to see if it was going to lay a decent bead.
Name:  Welder photos2.jpg
Does it not look a little funny to you guys, it has a yellow flake on it after the weld cools down???
Old 09-05-2012, 07:50 PM   #12
mongoose
mongoose's Avatar
looks fine.
Old 09-05-2012, 09:11 PM   #13
El Campo
El Campo's Avatar
Definitely not flux core. All welds look like that with a wire machine, I believe it is just "normal" trash on the metal (see how dirty your metal is?). My Miller 252 does it too when I do not clean the steel very well..
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-05-2012, 10:11 PM   #14
tex_waco_usmc
I appreciate it! I'm still wondering why the gas wasn't blowing before today!?!?
Old 09-06-2012, 12:30 AM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I bought a 210MVP new, and I had to click the trigger probably 20 times after unboxing and setting it up to get the solenoid to work. I swear when they aren't used for a couple weeks, they stick closed.
I've heard that leaving pressure in the line between the tank reg and the solenoid ends for a period of time can get the solenoid to stick, I always turn my gas off and purge the line if I'm not gonna be using it for a little bit.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-06-2012, 10:13 AM   #16
tex_waco_usmc
Awesome!
Thank you!
