Old 08-23-2012, 05:27 PM   #1
slammed427
slammed427's Avatar
1992 Half Ton Steering Issues
Hiya Folks,
I'm working on my sisters 92 half ton 4x4. Threw a new steering box in it today, her dude replaced the power steering pump a few months back.
The problem I'm having is when it gets up to operating temperature, the steering is uber stiff, but only in the low rpm range. I'm a reasonably strong fella, and I'm having issues turning it. When the rpms are up a bit, its fine.
Any ideas? I'm going home tomorrow and would like to get this sorted out.
Thanks in advance.
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 08-25-2012, 09:12 AM   #2
scotts62
One day...
scotts62's Avatar
Re: 1992 Half Ton Steering Issues
Sounds like the pump to me.
Scott
93 crew cab build
Project 62
Old 08-25-2012, 03:48 PM   #3
slammed427
slammed427's Avatar
Yep. Warrantee'd the pump out and its all kindsa sweet now. Almost makes me want to give up my squarebody habit... Almost.
Instagram: mmmdropp
Old 08-25-2012, 05:57 PM   #4
scotts62
One day...
scotts62's Avatar
Scott
93 crew cab build
Project 62
Old 12-18-2012, 01:09 AM   #5
chris989
I have the exact opposite,,
I have a 2500 4wd and my new steering box is so light it feels like the truck is on a lift. I have zero resistance. It actually feels unsafe to drive.
Anyone have this?
chris
chris989 is offline   Reply With Quote
Old 12-18-2012, 11:04 AM   #6
slammed427
slammed427's Avatar
Was it like that before hand? What caused you to changing the box?
My square was doing that a couple weeks ago, I got under there and found the bolts had worked their way loose. A bit of loctite and new lock washers and I'm good.
May want to check out your front end too. How long since everything was greased? Are all your ball joints and bushings still in good shape?
Instagram: mmmdropp
Old 12-18-2012, 11:06 AM   #7
chris989
my steering was firm before, It had a leak at the input shaft so while it was in the shop for a rear main i had the box changed.
