Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-24-2012, 12:33 PM   #1
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Next Outlaw 10.5 Race @ Shadyside Dragway, November 10th & 11th 2012
Next Outlaw 10.5 Race @ Shadyside Dragway, November 10th & 11th 2012, all classes will be running.
http://z3.invisionfree.com/Shadyside...howtopic=19570
OUTLAW 10.5 RULES FOR 2012
Outlaw 10.5 Rules 2012
1. 400 Pro Tree Heads Up Racing
2. Engine: (SINGLE POWER ADDER ONLY)
A. Naturally Aspirated
Small Block No minimum weight
Big Block No minimum weight
B. Nitrous Oxide:
Small Block 2300 lbs
Big Block 4.840 & 4.900 Bore Center 2600 lbs (tube cars add 50 lbs)
Big Block 5.00 Bore Center 2700 lbs (tube cars add 100 lbs)
Big Block 5.20 & 5.30 Bore Center 2800 lbs (tube cars add 100 lbs)
C. Turbo Charged and Super Charged (all forced induction tube cars add 100 lbs)
Single SB 2600 lbs Big Block 2700
Twin Turbo up to 94mm SB 2800lbs BB 3000 lbs
Twin Turbo larger then 94mm SB 2900 lbs BB 3100 lbs
Centrifugal Superchargers SB 2600 lbs, BB 2800 lbs
Twin Centrifugal Superchargers SB 2800 lbs, BB 3000 lbs
Roots Supercharger SB 2600 lbs, BB 2800 lbs
Max bore spacing on all forced induction at above weights is 5"
Any forced induction at 5.300 bore spacing add 100 lbs
Max cubic inch on all forced induction entries is 700 cid
Max turbo size 108mm on 5" bore spacing.
Max turbo size 94mm on 5.300 bore spacing.
*Screw superchargers:
"D" rotor 3000 lbs. Max O.D.125%
"C" rotor 3100 lbs. Max O.D. 125%
4 & 6 cylinder alcohol & intercooler permitted No minimum weight
3. Back Half Type Cars Only, Tube cars allowed must add weight, All cars mufflers Recommended
4. Front Frame to be original O.E.M. type. (stock like front frame rails mandatory) Direct bolt in aftermarket Parts permitted. Firewall must be in the stock location. Engine must remain in front of firewall. Firewall can not be modified for engine placement. Tube cars will be allowed must have stock appearing body steel top & quarters (no pro mod body’s.)
5. Must be Street appearing, must have stock appearing dash and working lights, one piece fiberglass front ends permitted. Hood can be a part of front end. If you use a one piece fiberglass front-end, it must have lights.
6. Alcohol on NON intercooled cars only.
7. NHRA Pro Ladder.
8. Minimum ground clearance of 3" from the front of the nose to 12" behind centerline of the front axle. Wheelbase must be OEM for body style used. Maximum variation from OEM +/- one inch.
9. Towing will be allowed, you must stop at scales and weigh when your class is called to the line.
10. General Rules: deep staging allowed, but track will not wait for a racer to get deep staged. When both Pre-staged are activated, either side stage light will start a 7-second stage count. Failure to activate stage bulb within 7 seconds will result in disqualification/timeout. (Starter's decision will be final). Disqualification will be based on a first or worse situation. Rules on controversial situations will be final at the discretion of the race director.
11. Head & Neck Restraint - Recommended
12. Lower engine containment device (Diaper) - Recommended
13. Maximum front overhang 45" From centerline of front spindle. Tire is limited 33x10.5
14. No car will be allowed to go faster than the chassis is certified for by NHRA.
15. Supercharger restraint system meeting SFI 14.1 mandatory on roots-type supercharger. Screw-type supercharger must meet SFI Spec 34.1 .
For screw-type superchargers, manifold burst panel meeting SFI Spec 23.1 Supercharger drive must be belt, NHRA-accepted chain driver or NHRA-accepted gear drive. Supercharger restraint straps must be covered with a fire-resistant material. See General Regulations 1.10
If one combination appears to have an advantage rules may be changed at track’s discretion in order to keep a level playing field for all competitors.
Upcoming Events @ Shadyside Dragway
http://z3.invisionfree.com/Shadyside...p?showforum=11
http://www.facebook.com/shadysidedragway
Shadyside Dragway
2149 Honey Haven Farm Road
Shelby, NC 28152
www.shadysidedragway.com
Track Office: 704-434-7313
Ronnie: 704-434-2895
Lennie: 704-434-0930
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
