08-24-2012, 08:10 PM | #1 |
20' Daredevil (Ret)
O-ring size help please
How to find the exact size o-ring for my transmission dipstick tube (72 K20)?
The one I removed seems quite new (I paid a shop to replace it a few years ago), but is leaking -- so it may be the wrong one. Comparing by size, it seems to be a #112, which is 11/16" OD x 1/2" ID x 3/32" thick. It seemed to fit the tube properly, but it was leaking. I have read that some brands are a bit thicker than others even though they are listed as the same size. Unfortunately my local NAPA has no o-rings, and the ones at Ace hardware (my only other choice) look exactly the same size as my old one. Any help would be appreciated! Thanks...
08-24-2012, 08:16 PM | #2 |
Re: O-ring size help please
I don't know the size but I believe this was the one I just bought for mine.
http://www.oreillyauto.com/site/c/de...smission+seals Did you get the bolt off finally? did you get it from the inside?? |
08-24-2012, 08:31 PM | #3 |
20' Daredevil (Ret)
Yup.... I'll post details in the other thread.
08-24-2012, 09:10 PM | #4 | |
20' Daredevil (Ret)
Just as importantly... it doesn't leak, does it?
08-24-2012, 09:26 PM | #5 |
I'm thinking that some of the automatics had a shouldered sleeve instead of an o ring.
I don't recall the applications but do remember changing a few of them. Might be something to check into. |
08-24-2012, 09:59 PM | #6 | |
20' Daredevil (Ret)
As to o-ring size, I found this thread http://www.stevesnovasite.com/forums...d.php?t=200111 which indicates the correct size is a #113, with 3/4" OD, 9/16" ID, and 3/32" thickness. The one I removed appears to be #112, with 11/16" OD, 1/2" ID, and 3/32" thickness. I have been unable to locate the thicker Danco brand o-rings mentioned in the above link.
