Old 08-25-2012, 06:47 AM   #1
Shamil
Shamil's Avatar
Issue with NP208 TC
Hello guys, I am facing an issue with my TC it is NP208. I noted the front drive shaft is spinning slowly even when TC is on 2H. I’ve checked the linkage under the cap and makes sure it is on 2H, I noted that when I hit the gas while the truck on a slope I can feel the front shaft is spinning and I feel the same some time when hitting the gas while turning the truck. Any idea what is the problem is.
Shamil is offline   Reply With Quote
Old 08-25-2012, 09:22 AM   #2
legendman
legendman's Avatar
Re: Issue with NP208 TC
Do you have manual or auto locking hubs on the front axle?
With the truck in 2H and hubs unlocked can you get under it and turn the shaft by hand?
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 08-25-2012, 09:49 AM   #3
Shamil
Shamil's Avatar
i have manual hub lock, and yes with the truck on 2H and the lock on free i can turn the front shaft
Old 08-25-2012, 11:06 AM   #4
legendman
legendman's Avatar
It's just friction of the fluid turning the driveshaft then, I wouldn't worry about it.
Old 08-25-2012, 12:09 PM   #5
hatzie
Moderator
hatzie's Avatar
There's always some slight mechanical drag that could turn the front shaft.
Are you running Dexron III in this case? Service docs call for Dexron II but Dexron III is compatible. Don't fill with Dexron VI unless you feel like replacing the seals.
Gear oil will eventually burn out your case bearings it's too thick to flow at the rate the engineers set this case up for. Bronze synchros don't like he sulfur EP compounds in GL5 gear oil either. Gear oil might cause enough drag between the shift synchro and sprocket to spin the front shaft. If you pull the fill plug and it smells like sulfur drain and re-fill with Dexron III.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 08-27-2012, 04:58 AM   #6
Shamil
Shamil's Avatar
i talked to my mechanic guy i found that he filled the TC with Oil 90... what you guys recommended is ATF.
Old 08-27-2012, 11:23 AM   #7
Mattman2010
Mattman2010's Avatar
All my 205 transfercases do this as well. It's just the gear lube causing it.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 08-27-2012, 11:16 PM   #8
hatzie
Moderator
hatzie's Avatar
Don't use gear lube in an NP208.
Factory lube in 1982 was Dexron II ATF. Drain it and refill with backward compatible Dexron III ATF before you spin the bearings.
