Old 08-25-2012, 05:22 PM   #1
'65Burb
electric windows
One of these days I'm going to get caught up on my other projects and I can then devote attention to my '65 'Burb. To that end, yesterday I picked up a couple of spare doors. The ones on the 'Burb are showing a little rust through. I want to cherry up these new doors and then mount them. I want to incorporate electric windows when I do this. How have some of you done this? Do I need the stock regulators, or is there a kit out there with everything? Thanks.
'65Burb is offline   Reply With Quote
Old 08-25-2012, 06:19 PM   #2
gofastnut
gofastnut's Avatar
Re: electric windows
I know autoloc has several kits, but I'm not sure of the quality of them. They do make one that lets you keep your window handle and tilt it 15 degrees up or down to roll the window, well, up or down. Again, they look cool, but not sure about quality.
Anybody else's 2 cents?
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 08-25-2012, 06:31 PM   #3
ozzyman
ozzyman's Avatar
There are a few on the board who have tackled this project and it looks like a lot of work. It usually requires cutting up the door behind the cover to accomodate everything. I'm sure someone will chime in but I would search the projects forum for "electric windows"
Active Duty Air Force 02'-Current
Proud dad of 3 girls, 1 boy and 1 TBD in Dec of 2012 - Lucky Husband
"Family owned and operated since 1969"
Dad's 66' Custom Camper - Big Family Small Budget
ozzyman is offline   Reply With Quote
Old 08-26-2012, 11:02 AM   #4
'65Burb
Thanks for the suggestion on search. I did not realize there was that "project" section. Yeah, it does look like a lot of work and I am OK on keeping the vent window. May have to see if I can engineer something up then document it for others.
Old 08-26-2012, 12:29 PM   #5
tincan1966
tincan1966's Avatar
Electra life make a bolt in kit that requires no modification except for running the wires and switches. They bolt into existing holes, and use original lower window guides, etc. Not cheap, but work very well and smooth.
Have heard several complaints about the AutoLoc units being noisey, but have never installed them.
This is another example of "do you want cheap, or do you want quality"
I personally would rather spend a little more now, then have to spend more again later.
We install alot of accessories in our shop, and are almost refusing to install the cheap crap customer's buy off craigslist and Ebay. There's a reason why it's so cheap or a "good deal"
Do some research about different manufacturers. Careful when pricing kits- some throw out cheap prices, but then you have to buy switches and harness as extras.Others are a complete kit ready to install.
A few to mention are:
Spal (usually less expensive)
Electra-Life
Specialty Power windows
...just a few
Realitsically, you should be able to install a quality kit for around $350
tincan1966 is offline   Reply With Quote
Old 08-26-2012, 07:27 PM   #6
'65Burb
Tincan, I'm with you. I've reached that point in life where I will get a good kit even if it costs a few more bucks to defray the cost and time involved with trying to piece something together. I appreciate the tip and will check it out.
Old 08-26-2012, 09:07 PM   #7
TopFuel1966
TopFuel1966's Avatar
I used these with Hotronics crank switches..............
http://www.a1electric.com/Merchant2/...t_Code=GM103-K
TopFuel1966 is offline   Reply With Quote
Old 08-26-2012, 09:25 PM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Nu-relic is the only way to go IMO
http://www.nu-relics.com/
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-26-2012, 09:33 PM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
I used electric life and you have to drill two holes at the bottom of the door. I didn't care for that but I have Rod Doors door panels that cover them. if I had to do it again I would go with the Nu Relic stuff.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-27-2012, 09:12 AM   #10
'65Burb
Little more dinero, but I'm thinking Nu-relics is the way to go. Electralife needs to work on their website because I could not find a listing for the trucks. Thanks again to all for the leads.
Old 08-27-2012, 10:04 AM   #11
McCoyAZ
McCoyAZ's Avatar
Speaking of keeping the vent windows...........
I looked into having my door windows made into one piece glass and adding electric locks but when they quoted me $1000.00 per door to do it I figured I could live with that ugly vent window and learn how to use a crank.
McCoyAZ is offline   Reply With Quote
Old 08-27-2012, 10:28 AM   #12
Chevy Fleetside
I bought mine through Summit .
This is pretty much what they look like. Need to drill holes but not spacing is needed to make them bolt in after that. http://www.summitracing.com/parts/EL...65-K/?rtype=10 This is what I could find when doing my truck and that was about 12 years ago. Damn time flys by
Old 08-27-2012, 07:07 PM   #13
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: electric windows
http://67-72chevytrucks.com/vboard/s...d.php?t=418555
http://67-72chevytrucks.com/vboard/s...d.php?t=412104
http://67-72chevytrucks.com/vboard/s...d.php?t=504919
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 09-04-2012, 09:35 PM   #14
jamesrussell26
i recently found a company that sells a 3 piece kit for truck to delete the vent window, the glass id 395.00 plus shipping you can even get the glass tinted. aaaaaaaarrrrrrrrrgggggggggggg now i got to find the link and post it btw the kit was for rear glass and both doors.
jamesrussell26 is offline   Reply With Quote
Old 09-05-2012, 09:52 AM   #15
'65Burb
I am accumulating all my parts to rebuild the doors. My Nu-relics should arrive today. Now, when the heck am I going to get to all this given all of the projects ahead of my 'burb?
Old 09-05-2012, 07:00 PM   #16
jamesrussell26
glass link....http://www.vintageglass.com/index.ph...ct_detail&p=15
