Hello Chevyland:
(1979 C20, 350 GM Mr. Goodwrench Motor 65k miles, running 10w40) Reader's Digest version: **Thought oil pressure sensor was bad (bouncing needle) Repalced OPS, didn't fix it. **Switched to mechanical gauge, and no more bouncing, however (warmed up) @ Idle 11psi, and cruising @ 45mph only 32psi, nothing higher even though RPM's go up to 2500.... When i put it in N, and bring up RPM's highest goes is 40 psi, nothgin more. Is this normal? PLease advise. Thanks for all your input! Willywoo |
Re: Another Oil Pressure Question
Thanks!
