Old 08-25-2012, 09:33 PM   #1
weider1717
Went to grease 87 4x4 only saw 5 zerk fittings?
All together I only saw 5 zerk fittings.
3 on the left front and 2 on the right front which one of those was a zerk on what I guess is the front u joint to the 4x4 diff.
the ball joints look to be sealed on both upper and lower..
am I missing any?
weider1717 is offline   Reply With Quote
Old 08-25-2012, 10:20 PM   #2
weider1717
Re: Went to grease 87 4x4 only saw 5 zerk fittings?
Took another look still only see 5 zerks.
2 on the pitman arm rod one on the steering box end and one on the other.
2 (one on each side) of the I guess it's called tie rod? that stretches from one side to the other
and 1 on the u joint SHAFT just beside the joint where it connects to the front diff.
anymore?
Old 08-25-2012, 10:53 PM   #3
86c20
86c20's Avatar
my 85 k30 has them all over the front end (dana 60) but has/had 0 on the drive shafts. slowly swapiing them out. could it me aftermarket junk? new cars have none
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 08-26-2012, 04:37 PM   #4
weider1717
ttt
