Old 08-25-2012, 11:00 PM   #1
rob32472
Any one using the entropy lsx swap rad?
what upper hose did you use? Any help is appreciated!
rob32472 is offline   Reply With Quote
Old 08-26-2012, 09:33 PM   #2
69trk
69trk's Avatar
Re: Any one using the entropy lsx swap rad?
I have one, but haven't installed it yet...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 08-27-2012, 10:54 PM   #3
jtp67-72
jtp67-72's Avatar
Installed but no hose yet...I know Rob we ain't much help......lol....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 08-28-2012, 06:47 AM   #4
rob32472
maybe i will figure before you are ready and help you.... Thats what this place is all about... helping others who have the same love for these trucks as I do
Old 08-28-2012, 09:59 AM   #5
jtp67-72
jtp67-72's Avatar
same here.....this is a nice piece....jim
Old 08-28-2012, 10:04 AM   #6
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I have this radiator, actually mine is one of the early ones they built so it is a little different than yours. I have some fitment issues, but it is in there. I guess the factory 1500 truck lower hose will work, but I haven't had an opportunity to look at the upper yet. Please share if you get there before the rest of us! lol
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 08-28-2012, 10:09 AM   #7
jtp67-72
jtp67-72's Avatar
I moded the bottom brackets to come back toward engine an inch or so with 4 core rubbers ...fit good...we will see on upper hose....jim
Old 08-28-2012, 10:23 AM   #8
C10_ustacould
I used the 4 core mounts also, but left them in the stock location. Being an early version, mine is not exactly "factory fit" like the web site says. You must have trimmed the lip off of the core support to move the lower mount back then, right?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-28-2012, 10:32 AM   #9
jtp67-72
jtp67-72's Avatar
Originally Posted by bucksss View Post
i used the 4 core mounts also, but left them in the stock location. Being an early version, mine is not exactly "factory fit" like the web site says. You must have trimmed the lip off of the core support to move the lower mount back then, right?
yep
Old 08-28-2012, 01:24 PM   #10
rob32472
I had them weld a tab on top and bottom so I could use my factory three core mounts this made it a true bolt on.....
Old 08-28-2012, 01:48 PM   #11
C10_ustacould
Any pics?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-10-2012, 02:31 PM   #12
C10_ustacould
Any one using the factory truck lower hose? I also thought about using these, http://www.summitracing.com/parts/SUM-390024/, for the upper and lower hoses. What do you all think?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-10-2012, 05:23 PM   #13
rob32472
Used them on the last build they worked fine and look great
Old 09-10-2012, 07:36 PM   #14
C10_ustacould
It seems to be the easy route, but I'm not sure about the look. But, heck it's got a late model fuel injected engine so I guess I need to let go of the idea of the factory look!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-10-2012, 10:18 PM   #15
jasonhall
jasonhall's Avatar
Would the factory 5.3 hoses work with the radiator ?
jasonhall is offline   Reply With Quote
Old 09-10-2012, 11:30 PM   #16
C10_ustacould
The lower is a possibility, but the upper is on the opposite side.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-21-2012, 01:26 PM   #17
BigShoe24
True Addiction
BigShoe24's Avatar
Looking to purchase this piece... it looks like the trans lines hook up on the driver side? Thanks
RCC
BigShoe24 is offline   Reply With Quote
Old 10-21-2012, 05:17 PM   #18
C10_ustacould
They do. I didn't use them, I used an AFCO cooler mounted on the frame rail.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-21-2012, 08:26 PM   #19
BigShoe24
True Addiction
BigShoe24's Avatar
Buck,
Any particular reason why you decided not to use them? Do you think it would not be suffice to cool the trans? Thanks
RCC
Old 10-21-2012, 08:52 PM   #20
C10_ustacould
I like to use the AFCO rail type coolers and braided lines for simplicity. It's just plain easy.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-04-2012, 07:59 PM   #21
BigShoe24
True Addiction
BigShoe24's Avatar
What are the lower mounts for an original 67-68 rad support, I'm guessing 3 row? Also, jtp67-72, did you go with the regular or HD upper cover/mount?
Thanks guys
RCC
Old 04-23-2013, 01:24 AM   #22
suttoncurt
suttoncurt's Avatar
Any updates on this subject ? I have this rad , and getting close to installing it . Thanks in advance for the help !
suttoncurt is offline   Reply With Quote
Old 04-23-2013, 02:04 PM   #23
suttoncurt
suttoncurt's Avatar
Did you ever find a upper hose that worked for ya - I'm using the fbody water pump to the entropy rad . Thank you !! I'm looking for the upper hose at the part stores today .
Old 04-23-2013, 02:19 PM   #24
JJH Jimmy
JJH Jimmy's Avatar
I got one from Entropy. I have it installed but have not used it yet. The quality is excellent. I talked to Tony and had him modify a standard 67-72 radiator so the inlet and outlet connections were the right size also, this way the transmission cooler was on the passenger side of the radiator and I could use stock truck hoses.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 04-23-2013, 02:49 PM   #25
suttoncurt
suttoncurt's Avatar
Sweet looking set up !! Yes the quality of the rad is great ! I should have mine in this weekend just trying to figure this upper hose out - both my hoses are on the passenger side . Good luck with your build and I hope it runs great for ya ! Thanks for the input
