Old 05-24-2003, 09:22 PM   #1
Low69CST
Header heat making my oil filter glue to the block?
I changed the oil again today on my 69. It was all i could do to get the oil filter off. I don't think i'm putting it on too hard, I have 2 other trucks i drive and have no problems getting them off, but on my 69 I have a set of headers that run fairly close to the filter. Could those be making my filter glue itsself to the block?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 05-24-2003, 11:39 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Hmmm, running headers myself since '98 and never had this problem.
Old 05-25-2003, 12:17 AM   #3
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
I'm running headers and did have that problem. But I use synthetic and don't drive my truck everyday. So I only change the oil once a year in the spring. 7 quarts of full synthetic gets rather expensive.
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
Old 05-25-2003, 01:52 AM   #4
SEVEND2
SEVEND2's Avatar
a friend of mine made a heat shield for his to cover the starter and oil filter.. he used hose clamps to mount them to headers
maybe some thing to think about and try, might work
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 05-25-2003, 04:46 AM   #5
73stepside
73stepside's Avatar
mine does that. i have to use filter pliers to get it off. if looks like channel locks with big teeth. they will crush and pierce a filter no problem. but they sure do make it easy to get off.
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 05-25-2003, 06:33 AM   #6
68 Suburban
68 Suburban's Avatar
Another reason why I will never use headers again
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-25-2003, 09:06 AM   #7
Low69CST
I've got a 6 quart pan with kickouts on the side, plus the headers so its kind of difficult to get to. I don't even run the truck that long, I just start it up for a few minutes, let it heat up and let the fans coolit down through a couple of cycles and shut it off. Maybe its just the tendancy of the oil filter strap thing I have to crush the filter while your taking it off. I'll try using this strap on my S-10 and see if I get the same results.
Old 05-25-2003, 09:40 AM   #8
Blue Beard
Blue Beard's Avatar
My question would be was the oil filter gasket lubed before the install....?
Just a thin coat of oil on the rubber gasket will make a big difference......and don't over tighten..
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 05-25-2003, 10:25 AM   #9
Low69CST
yeah, i always put oil on the gaskets and fill up the filter as much as possible with oil. I've got 2 other trucks I change oil in and never have this problem.
Old 05-25-2003, 12:39 PM   #10
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I had the same problem on my 69, the headers come very close to the filter and hardly any room for a filter wrench, I went to a 2 qt filter [fram ph373], this brings the filter below the headers and I believe keeps the filter cooler.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 05-25-2003, 03:08 PM   #11
Alaskan
Truck'n the alcan
Alaskan's Avatar
You could go to a remote filter using a relocation kit. Just my 2 cents
68 GMC 4x4
71 C20 Custom Deluxe
83 1/2 ton conversion van
Alaskan is offline   Reply With Quote
Old 05-25-2003, 03:52 PM   #12
Low69CST
Theres no way in the world I could use that 2 qt. filter. Mine is sitting on the ground. So the long filter would be trouble on my ride. I've thought about using an oil cooler, but the thought of a loose line scares me. I may try to make a heat sheild for it.
Old 05-25-2003, 04:21 PM   #13
ckhd
ckhd's Avatar
It looks like those headers are touching the filter! They are very close.
I think it could easily be causing your problem. It could also cause other problems too, like getting the oil too hot... doing bad things to the element in the filter, etc...
I would definately get a filter relocation kit and move the filter somewhere else.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 05-26-2003, 02:34 AM   #14
SEVEND2
SEVEND2's Avatar
I got the hedman headers made for 67-72 350 engines style trucks. got lots of clearance
and stage 2
Old 05-26-2003, 06:34 PM   #15
cruzn72
I used to have a set of full lenght headers on my 350. I never had a problem with the filter sticking. I now have a set of block hugger headers and there is a ton of clearance.
http://photos.yahoo.com/cruzn72@pacbell.net
cruzn72 is offline   Reply With Quote
Old 05-28-2003, 02:21 AM   #16
ZOOMY
filter
Bluebeard hit it right. Lube the gasket with some oil and hand tighten only !!!
ZOOMY is offline   Reply With Quote
Old 05-28-2003, 09:51 AM   #17
jku72
If the oil on the seal is burning off, or cooking the rubber, try using some high temp antisieze instead of oil. Just be sure not to gunk it so that it goes into the oil side.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 05-28-2003, 10:19 AM   #18
68 Suburban
Blazerman, you need a skid plate just for your oil filter
