Old 08-26-2012, 09:24 AM   #1
C5Phil
C5Phil's Avatar
Leaf Springs replace or repair?
My 70 GMC leans to the drivers side about 1". Is there a simple solution and/or do I need to replace them? Would like to save some bucks for disc brake upgrade and new seats - so it is drivable but looks funny--
C5Phil is offline   Reply With Quote
Old 08-26-2012, 09:41 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Leaf Springs replace or repair?
Can you actually detect a 1 inch drop or did you just do some measuring on the rear? If it's something you can't live with you could shim the low side or replace both sides. There are other leaf springs that fit. Just measure the width and length and check in salvage yards.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-26-2012, 09:58 AM   #3
C5Phil
C5Phil's Avatar
I just measured to the same place on the rear frame from the ground when the truck was sitting on level ground-- how would I shim the low side spring?
Old 08-26-2012, 11:11 AM   #4
68gmsee
Active Member
68gmsee's Avatar
You can add under the leaf springs on top of axle. On mine I actually had to remove a couple. It came with 8 springs. Just make sure that you don't have any broken or worn stuff down there like shackles or bushings.
Here's a good site for some info.
http://www.generalspringkc.com/Leaf_...972_s/1822.htm
06 Trailblazer
Old 08-26-2012, 11:17 AM   #5
68gmsee
Active Member
68gmsee's Avatar
One other thing I forgot to mention. The problem could actually be in the front. If the left front is low, the right rear might show higher. Sorta like a criss/cross see/saw action.
06 Trailblazer
Old 08-26-2012, 11:37 AM   #6
C5Phil
C5Phil's Avatar
Got it-- Thanks for the info. I'll try adding something under the u bolt-- any suggestions for what i could use? I think the front is OK- the front coils may be a bit weak but the are the same age so.....
Old 08-26-2012, 11:55 AM   #7
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Are you sure the 1" is in the frame to road, not the body clearance or
a bumper to road appearance?
If it's in the frames ride height, 68gmsee has a good point...could easily be
something in the fe manifesting itself in the rear (called wedge).
I'd think the least labor intensive check for that (with no cash outlay) would
be to support the rear of the frame and measuring the fe clearance or to swap
your front springs side-to-side and see what happens.
IMO, way easier than goofing with the leafs, if you don't have to.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 08-26-2012, 12:53 PM   #8
C5Phil
C5Phil's Avatar
I'd think the least labor intensive check (with no cash outlay) would be to
It's really more like 3/4 of an inch but it is frame height to ground as I measured it with my box off the truck... It very well could be in the front- right now its not a huge problem and my priorities are more for getting good brakes and a comfortable seat installed-- but thanks for the info. I'll make sure to check the front before I do anything--
Old 08-28-2012, 01:02 AM   #9
OldCreek
OldCreek's Avatar
Conceivably, you could add a 1" zero rate block on the driver side...but I'm not sure if that would be considered safe or not.
Or, you could switch the springs from side to side so that when you're in it maybe it evens out a bit...but don't do this if your lady rides with you a lot!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 08-28-2012, 08:54 AM   #10
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Originally Posted by OldCreek View Post
...you could switch the springs from side to side ...
Yup. Just like a vibration...swap around the suspect part(s) and see if the symptom follows.
Also, only one change at a time so you know where the problem is when you find the culprit.
Do your measurements from frame to axle to take the wheels/tires out of the equation.
Subscribed so I can follow this over to the suspension forum.
Old 08-28-2012, 09:18 AM   #11
C5Phil
C5Phil's Avatar
good ideas.... thanks to all for the input--
Old 08-28-2012, 10:49 AM   #12
newbe351
So simple, yet I probably would have overlooked this as well. That's why I love this board......
newbe351 is offline   Reply With Quote
