Old 08-26-2012, 10:18 AM   #1
briank
roll bar question
I dont know much on the 73+ k5's. Will a rollbar from a 74 fit in a 72? If not, whats the difference? Thanks
briank is offline   Reply With Quote
Old 08-26-2012, 07:10 PM   #2
Firebirdjones
Re: roll bar question
Nope. The rear section of the floor was changed (lower I think) so the step isn't there or is much less pronounced.
Firebirdjones is offline   Reply With Quote
Old 08-26-2012, 09:29 PM   #3
briank
Thanks, I didn't think it would. A fellow K5 blazer owner here in my town needs one and came across a '74 roll bar and asked me if it would work. I told him I doubt it but I would check.
Old 08-27-2012, 11:21 AM   #4
fun in dirt
fun in dirt's Avatar
This is the rollbar that was in my 72 when i got it & somebody said it was out of a 2nd gen Blazer (which would be 74 style). It fit, but leg just sits kind of low on the wheel well.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 08-27-2012, 11:37 AM   #5
briank
Thanks for the pic, Ill let the guy know
Old 08-27-2012, 11:47 AM   #6
Firebirdjones
It's also sitting further back from the door frame than the correct bar would,,,and that's because the down bar is so short for the 2nd gen blazer,,,that the entire thing had to be moved back to touch the wheel well in your first gen.
Old 08-27-2012, 01:03 PM   #7
MrGoodpliers
MrGoodpliers's Avatar
I think it might fit. Back in high school, a friend of mine had two blazers, a '76 and a '78. The '76 had the high floor like a '72 and the '78 had the lower floor.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 08-27-2012, 08:19 PM   #8
badpeanut
Not a bad nut after all..
badpeanut's Avatar
'78 was the first year the Blazer received the lower floor ahead of the rear seat.
'73-'75 still had the full removable hardtop. Attached is a picture of a factory '73-'75 roll bar in a '71 Blazer. The tubes fit well. The ribs in the bed floor don't line up well.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 08-27-2012, 09:10 PM   #9
briank
Thanks for the pics
Old 08-27-2012, 10:50 PM   #10
Firebirdjones
If that's a factory 73-75 roll bar,,,,it's completely different than the 69-72 bars made by Hinkle.
Hang on and I'll see if I can find a pic of the original Hinkle bar in mine.
Old 08-28-2012, 09:16 PM   #11
1972k5blazer
I think that last picture is a factory roll bar , i sold one to a member awhile back just like that and i unbolted it from a 73 + blazer and the floor was threaded for the roll bar , looked good in my rig i just couldnt make myself drill holes in my floor to mount it.
1972k5blazer is offline   Reply With Quote
Old 08-28-2012, 10:30 PM   #12
Firebirdjones
Here is what the Hinkle 69-72 bar looks like.
Old 08-29-2012, 09:19 PM   #13
cst 72 blazer
cst 72 blazer's Avatar
i put one out of a '82 in mine. cut the front legs off to what i needed and weld new mounting plates.worked out just fine
Chris Heinz
cst 72 blazer is offline   Reply With Quote
Old 08-29-2012, 10:30 PM   #14
7D2N
7D2N's Avatar
Briank,
If you are looking for different options, I used a truck roll bar, shorten the legs a bit to clear carpet and headliner.
7D2N is offline   Reply With Quote
Old 09-07-2012, 01:28 PM   #15
rfsnyder
rfsnyder's Avatar
badpeanut is correct.... the '73-'75 style roll bar fits within the sidewalls and under the hardtop just find, but the existing floor supports or "feet" do not line-up with the ribbed floor.
Name:  Roll Bar in Place.jpg
I just finished installing the '73 style roll bar in my '72 blazer... with modifications of course. I cut the existing feet off and even cut the seat belt bracket off as well, for I thought it was just too low and in the way of the sidewall. I created four new brackets for the mounting feet and welded them to the bar. As you can see by the picture, the feet span multiple ribs in the floor, are contoured with the floor, and go all the way to the sidewall.
Name:  Roll Bar Feet.jpg
TIP: With the mounting brackets/feet going all the way to the sidewall… getting the roll bar in and out of the truck is nearly impossible! I use a tie-down strap from side to side and ratcheted a few times to pull the roll bar together, giving you room to maneuver the bar in and out of the truck. The roll bar will flex more than you think and will retain back to its original form. Just don’t ratchet it too much!
The placement of these with the floor support structure within the undercarriage is important! I was able to align the back section such that it aligns with the floor supports underneath and plenty of room for mounting bolts. This is great for added strength and rigidity! The front supports are easily accessed from the undercarriage as well, even with the rocker box. I also have a flat plate that is mounted from the undercarriage and sandwich it all together. Very strong!
On another note, I wanted a three-point seat belt harness… so I drilled through the roll bar and welded in a grade eight nut to mount the shoulder point. I’m sure this is OSHA approved!
Name:  Seat Belt Support.jpg
rfsnyder is offline   Reply With Quote
Old 09-08-2012, 11:39 PM   #16
badpeanut
badpeanut's Avatar
Nice roll bar feet fab and nice welds rfsnyder!
Your bar looks really clean without the seat belt brackets, but the width is just right that they could serve as a support to the front edge of the box sides (improve how the doors close?).
IIRC the '73-'75 foot had two 3/8" bolts, and I see you have four bolts per foot. What size bolts did you use?
'70 GMC LWB trailer
Old 09-09-2012, 03:20 PM   #17
jaros44sr
jaros44sr's Avatar
Well done rfsynder, nice write up...want to make another set of feet?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-09-2012, 04:55 PM   #18
joemacho
joemacho's Avatar
heres my roll bar it came out of a 85 blazer i had to do the same cut out the front and middle bars to fit but it still needs the feet plates to fit just right just like 7d2n.
1972 gmc jimmy project comin soon ( jus a sin )
1959 chevy apache shortbed fleetside (brsgrm)
1966 Chevy c30 duallie 2wd (big chief)
joemacho is offline   Reply With Quote
Old 09-10-2012, 10:26 AM   #19
rfsnyder
rfsnyder's Avatar
Badpeanut - For bolt sizes... I'm using 3/8" grade eight bolts. By the way, I'm not a very good welder... but one H$LL of a grinder! I created an "L" bracket for the seat belt retractable "box" and plan on using the existing seat belt mounting hole/bolt. It's close to the door, but not bad.
jaros44sr - I'm willing to create another set.. but I recommend that you drill the holes, just so you can line everything up with the supports in the undercarriage. PM me and we can discuss.
Old 09-10-2012, 03:29 PM   #20
jaros44sr
jaros44sr's Avatar
Thanks snyder, let me get my thoughts and drawings together...i have a 1/2 top, so i have to move my stock bar around
SAFETY FIRST
AS usual, off topic
Jim
Old 09-29-2012, 12:01 AM   #21
hilljob26
hilljob26's Avatar
Originally Posted by 7D2N View Post
Briank,
do you know what year of truck that roll bar was for,,thats the route oi think i will be going
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 09-29-2012, 10:31 AM   #22
7D2N
7D2N's Avatar
Hilljob26, The roll bar was in a 74 short bed chev truck. I looked for an after market this style with out any luck. I see a few in pick-up every now and again.
7D2N
Old 09-29-2012, 09:40 PM   #23
hilljob26
hilljob26's Avatar
sweet
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 10-21-2016, 01:27 PM   #24
Lieferson
Lieferson's Avatar
Old thread revival, but if i found a 75 roll bar for 20$, all brackets intact, should i just get it and modify it? anyone unhappy with their later model roll bars?
1970 1/2 ton 4x4 4spd Suburban
1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
