08-26-2012, 04:24 PM | #1 |
NP203 Issue
It is a 79 NP203 mated to a th350 the issue is when in lock it will pop out of lock either high or low with any type of medium or heavy acceleration and it is particularly annoying considering my front driveshaft is out and it not having a part time kit please tell me it is something small I would like to be able to open up my new motor or even pass a car without it popping out of gear
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
08-26-2012, 09:45 PM | #2 | |
Re: NP203 Issue
08-26-2012, 11:34 PM | #3 |
Re: NP203 Issue
Yes I know this it is only out till I get the funds to replace the U-joints and it is my only form of transportation right know
08-27-2012, 06:03 PM | #4 |
Re: NP203 Issue
I looked on my own and came up with a couple possible solutions.
08-27-2012, 06:50 PM | #5 |
Re: NP203 Issue
I have a sneaky feeling that it might be the linkage or the shifter because it is very stiff shifting through the gears I think I will take the shifter assembly out to clean and lube it and I will adjust the linkage then. ratchet strap It would work though
08-28-2012, 01:16 AM | #6 |
Re: NP203 Issue
203 linkage is dog breath when they get old. Either will not fully engage and pop out or will not come out and get stuck between gears. I got tired of crawling under mine and figured out an easy way to convert to twin stick. Took me 3 hours including time to take the pictures for the thread. Just takes a hack saw, die grinder and welder. http://67-72chevytrucks.com/vboard/s...d.php?t=360447
And I know 203 is the ugly step sister, but I got good use out of mine, have a good spare and do not want to change just to change until I break both or them. With a shaft part time kit the wear issues are minimized.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
08-28-2012, 01:38 AM | #7 |
Re: NP203 Issue
08-28-2012, 07:24 PM | #8 | |
Re: NP203 Issue
